Page 2 of 2 FirstFirst 12
Results 26 to 37 of 37
over-heat and 6k idle?
    Westfield MA
    Re: over-heat and 6k idle?
    alright good news! i think i figured out why it was idling like that. The throttle slowly migrates back after placing it in its fully rested position (where its supposed to be snapped back to) so when i start it, the throttle is slightly open and thus explains the high idle. I may need to reorder some new cables because we just cant get it to stay in place. that or the spring is bad on the carb. does this seem acurate?
    could also be the routing of the cables.
    I've worked on bikes that required the cables to have an exact routing path for accepable operation....any other routing (sometimes within inches) would cause binding issues.
    Westfield MA
    no kidding? thats crazy! i put some new ones on order, the ones that are on there now are frayed pretty bad at the carb end. ill pay attention to the way they are supposed to be routed. if i have any probs ill post up. hopefully i dont
    Westfield MA
    oh and in case i dont get back to you guys. thanks for all the help and advice! NESR is the shiznit
    Westfield MA
    Any one know the correct way to rout these cables? i looked in my Haynes manual and all it shows is how to properly rig them. Any ideas? i understand that it just cant bind or kink. so does that mean i can rout them as i see fit? just want to do this the right way. thanks again guys!
    nate
    Lifer legalspeed's Avatar
    Somersworth, NH
    To check: after routing your cables, before you go out on it, let the bike idle and turn the handle bars from steering stop to steering stop.
    In other words check the full range of turning before you go out. If you turn the forks all the way to one side and the engine spins up without throttle input, you have a bind-up and need to re-route the cable.
    This can happen with your choke cable too.
    LRRS\CCS\WERA #486
    Westfield MA
    ok thats easy enough. thanks legalspeed
    Westfield MA
    ok so i replaced the accelerator and decelerator cables. the throttle snaps back, not great though. I checked the routing of the cables and it feels nice and smooth. I routed them so that there was no major bend. instead one open smooth bend from the carb around the frame and up to the throttle housing. we started it up and at first it idled at 2k...not bad considering where i was a month ago. but it still slowly migrates to the open position, like its reving itself up. I take the throttle and force it back up against the stop and the RPS drop down to where it should be when sitting idle. would a carb sync fix this? i know its old and i may of moved one of the adjustment screws on accident a few months ago... what do you guys think?
    also while im on the carb sync topic, anyone in western MA want to earn a little extra cash and do this for me? its beyond my repetuar and i dont want to pay a shop 80-90 bucks an hour to do this for me.
    mhm... *GhostRide37's Avatar
    Randolph MA
    6k idle???????
    1995 Yamaha FZR600- my learner, sold
    2001 Yamaha YZF-R1- stolen
    2005 Suzuki GSX-R 750- cutoff by an illegal U-turner and totaled
    2007 Yamaha YZF-R1- stolen... R1s are a hot commodity, huh? any anti-theft system suggestions?
    Current: 2009 Yamaha YZF-R1
    BenSmith
    Westfield MA
    Quote Originally Posted by *GhostRide37 View Post
    6k idle???????
    read the whole thread. it was caused by the throttle
    Randolph MA
    yea idc what it was caused by im just saying thats crazy. with my choke on blast my bike will do like 4k
    BenSmith
    Westfield MA
    yeah, i put my choke on and it jumps to about 10k... somethings pretty messed up lol
  1. KTM idle is sky-high
    By number9 in forum Bike Maintenance
    Last Post: 09-18-17, 11:51 AM
  2. Idle problems
    By spydah in forum Bike Maintenance
    Last Post: 08-28-08, 04:39 PM
  3. lowering idle to reduce heat
    By breakdirt916 in forum Bike Maintenance
    Last Post: 04-05-06, 07:06 PM
  4. idle problem on car
    Last Post: 03-05-04, 06:20 PM
