Got a friend who sunk WAY too much money into his Duc 695.
Along with a bunch of other mods he put a sssa on it form a Duc s4r.
He is riding along and the rear brake grabs, gradually getting worse and it is smoking when he stops, pretty much locked up. He lets it cool and is able to ride away but it gets hot, starts locking up and he stops again.
He brings the bike to me about a month after the incident rear brake seems to work ok. I replace the rear pads (down to nothing) and bleed the brake. Using a mighty vac I go through a bottle and a half of fluid and just barely get the brake working at full lever pressure.
I take it for a spin and it runs fine, I don't have any brake issues (of course the rear brake isn't bled well and is really not working).
Could this be a caliper piston issue? I am going to rebuild the caliper and see if that fixes it. Any other ideas?
Could it just be I need to bleed the brakes better?
If the seals are sticking, the brake will drag, which will cause the fun you've observed.
To bleed that system, you have to take the rear caliper off and hold it up above the master, so the loops in the brake line are no longer the high points in the system.
Well, brake fluid absorbs water. I believe if there's too much water in the fluid you might have the problem described since the water will expand as it heats up creating pressure in the system. And of course the engagement of the brakes causes more heat to be added to the system, which causes more expansion, etc etc...
Since you mention he added a SSSA... did the brake parts also come from that bike? or did he re-use his existing stuff?
2003 ZX7R
1995 916
They came off that bike.
is the break lever moving freely??
2006 Ducati Monster S2R800
as Honclfibr said
water in the fluid could cause it to. happend to my girlfriends bike and we changed the fluid out and it never happened again.
Seth
LRRS/CCS NV #256
2007 Ducati S2R1000 Street
2000 Triumph TT600 Track For Sale
1984 Honda Magna needing reassembly.
1974 Honda CB 750 needs wiring
1974 Honda CB 350 needs engine work
To much fluid in the resevoir.
Later,
Don-M aka Kid Thunder
You are correct! If there is a blockage in the cap breather or you have to much fluid it will act like you are riding brake.
Later,
