Page 2 of 2 FirstFirst 12
Results 26 to 33 of 33
Help with chain install
    Carlsbad, CA
    Re: Help with chain install
    I just bought an RK chain tool for < $100 and plan to use it as if I know exactly what I'm doing... otherwise, I figure the tool will sense my lack of experience and break on first impact with the chain. I mean after all, I stayed at a Holiday Inn Express last night (OK, well I watched a 3 part YouTube video on using a chain tool).
    Now for the rest of it:
    I'm set on a DID chain
    Anyone recommend some sprockets?
    Lifer SwiftTone's Avatar
    Norwood, MA
    Quote Originally Posted by nilez View Post
    I use DID ERV3 on Drive System's Superlite RS7 520 rear and JT's steel front sprocket.
    Pieced it together myself and paid about $200 total.
    Banned G21forme's Avatar
    Lakes
    I like supersprox personally, mostly because they look cool but I get good mileage out of them as well.
    Redistribution Supplier
    Just don't use the tool to break the chain,use a Dremel then push the pins out.Or better yet just cut the chain entirely.
    The pins should last a long time if used properly.
    Quote Originally Posted by FalArAk View Post
    Just don't use the tool to break the chain,use a Dremel then push the pins out..
    I agree with this. At a minimum, grind down the majority of the pin "head" and then use the tool... the pin will pop out easily and put virtually no pressure on the tool.
    Tony
    Trackdays in CT, NY, and NH
    www.TonysTrackDays.com
    Carlsbad, CA
    Quote Originally Posted by TTD View Post
    Sweet, thanks for the advice.
    Best- DID
    second best - EK
    I like EK and DID. I HATE Regina.
    It's been forever and a day since I have bought a chain:
    EK-SRX -OR- DID VX
    Both are x-ring type sealed chain... so I suspect the answer is either.
    Wirelessly posted
    Either.
    Lol
  1. Chain/Sprocket Install Technical Question
    By LXnastynotch93 in forum Bike Maintenance
    Last Post: 05-18-14, 12:03 PM
  2. Chain/sprocket install around Keene
    By SRTie4k in forum Bike Maintenance
    Last Post: 09-06-11, 01:10 PM
  3. Help with chain install
    By SRTie4k in forum Vermont Events
    Last Post: 06-23-11, 10:32 AM
  4. chain install ???
    Last Post: 06-14-10, 10:00 AM
  5. Can someone help me with a chain & sprocket install?
    By hqp921 in forum Bike Maintenance
    Last Post: 09-15-09, 04:10 PM
