Results 1 to 18 of 18
Help getting the Twin started?
    Pepperell, MA
    So I finally spent some time in the garage rather than in the house working. I got the new RC51 back in December and it ran fine than. A little over a month ago I failed trying to get it started. I drained the gas and refilled with fresh 93 Octane. Still will not start. I took out the filters and tryed starter fluid. Almost worked.
    So since the bike has yet agian sat. Tonight a changed the spark plugs and tried her again. It still sounds as if it want to turn over but will not. Came closer to starting with the starting fluid but just will not catch.
    I went to CAP and bought FI cleaner and octain booster to try that next, maybe tomorrow. I checked all the fuses and everything is fine, Any other idea's??? When I got the bike if fired up and ran perfectly. Battery is also ok and on a trickle charger right now.
    What should I try next?
    Degsy you out there???
    www.tailofthedragon.com
    Meriden, Ct
    Re: Help getting the Twin started?
    check for spark... If you have spark it should have lit off the starting fluid.
    Also, it's been sitting. Look carefully to make sure no unwelcome guests made dinner out of some wiring.
    Pepperell, MA
    All the wiring looks fine, no unwelcomed visitors left any evidence of taking a free ride.
    I am pretty sure there is spark because I have small flames exit both exhuasts a few times. I think I put too much fluid once or twice....
    How else is there to check for spark? I can only imagine I would have to dig out the connector wires and press the ignition key while looking in the boot of the contact?
    Lifer slammp's Avatar
    Jul 2008
    Massachusetts
    Stupid question but is the little red switch on the right hand grip set to run?
    Nov 2004
    Boston, MA
    Did you put the key in AND turn it?
    EVERYTHING is a repost
    06 749R #0047
    08 R 1200 GSA
    13 Monster EVO 1100
    Meriden, Ct
    Quote Originally Posted by slammp View Post
    And before anyone chimes in... YES, RC51s will crank with the kill switch in the off position...
    Nov 2004
    Boston, MA
    I will laugh......hard!
    06 749R #0047
    08 R 1200 GSA
    13 Monster EVO 1100
    Jul 2008
    Massachusetts
    2nd dumb question. Is it in neutral?
    Nov 2004
    Boston, MA
    I will laugh hard..........er.
    06 749R #0047
    08 R 1200 GSA
    13 Monster EVO 1100
    Pepperell, MA
    Come on now, really now.. I swear I am not an idiot...
    In Nuetral, key was in, & kill switch was in the on position.....
    Arg.. agrivating I really want to be able to ride sometime this year. House is in decent shape and I can afford to take a day here and there for a ride.
    Wirelessly posted (BlackBerry8330/4.5.0.160 Profile/MIDP-2.0 Configuration/CLDC-1.1 VendorID/105)
    Disconnect the power commander and try again.....and stop using ether to try to start it unless you want bent valves. Mike. Call me tomorrow after 9am.
    Jul 2008
    Massachusetts
    Good point on the power commander. You need to completely disconnect it if that is causing the problem.
    Lifer mycirus's Avatar
    Aug 2003
    Whitinsville, MA
    Its junk. Ill sell ya mine, runs mint.
    Bruce
    2007 VFR800 25th Anniversary
    2003 Honda RC51
    Starter fluid + gas engines = VERY bad
    Lifer richw's Avatar
    Aug 2004
    Baltic,CT
    Jump start the mother
    Or if gas was 3/4 full or less than it could have 2 qts of water/alchohol at the bottom of the tank.
    drain tank then jump the pump to clear it
    Glen Beck is John the Baptist
    Pepperell, MA
    Degs was right on with the power commander!
    I took it out reconnected the stock harness and it fired right up. Then I pulled out my old PCII from the old RC and installed it. Runs mint! I am glad I never sold the old one!
    Degs I owe you yet more beer! Thanks man.
    I'm hoping to get this registered and on the road soon. Tommorrow I shall give her a nice bath and install my GP shifter.
    Jul 2008
    Massachusetts
    Good deal!!
    Stupidhawks will too. Ask me how I know...
  1. My First Twin
    By Kitt in forum General Bike Related
    Last Post: 05-22-11, 07:06 AM
  2. I-4 vs. V-twin
    By GixerJockey in forum Pit Area
    Last Post: 04-05-09, 07:57 PM
  3. The joy of a twin....
    Last Post: 05-06-02, 09:50 AM
  4. The TWIN is IN!
    By cRa1g in forum General Bike Related
    Last Post: 07-31-01, 12:50 AM
