Results 1 to 10 of 10
So, they've taken all the zinc out of the oil
    NorthShore
    Under API SM/GF4, with zinc limited to 800ppm, and phosphorous and moly nearly eliminated owing to our friends at EPA and the folks that warrant cats, what are you guys using in your bikes these days? Additives, or the Honda-Suzuki-Yahmaha labled brands that fit the old SJ standard?
    I realize most new bikes have exhaust-stream air injection and cats, but even those still need the oil to protect the trannies..
    Re: So, they've taken all the zinc out of the oil
    Shell Rotella 15-30
    Apr 2008
    Boston, MA
    I don't know if this is related to flat tappet cams, but I know with our Turbo Buicks and some other older cars, we need to make sure we have enough of the zinc and phosphorus molecule or whatever. There is a supplement out there that is recommended for that called ZDDP. I haven't personally used it yet, I found a cheaper although probably not as good alternative for the mean time.
    EDIT: The supplement product is called ZDDPlus. Sorry.
    Littleton, Ma
    Wirelessly posted (Opera/9.60 (J2ME/MIDP; Opera Mini/4.2.13057/488; U; en) Presto/2.2.0)
    Mobil 1 10w-40 non energy saving.
    Gabba Gabba Hey Stiggy's Avatar
    Jan 2009
    Uh oh, oil thread.
    I'm an Amsoil guy. I use it exclusivley in everything I own. My VFR has the Motorcycle 10W-30 in it. I also use an Amsoil filter.
    06 RC46
    <---Thats a nice A$$! EFD 05 1K's Avatar
    Epsom NH
    Im running full synthetic suzuki oil and an oem filter. From experience, using the oil recommended from the factory is the best.
    05 Gsxr 1k Black/Silver, Yosh pipe, 8k HIDs, a very big grin
    NorthShore
    Quote Originally Posted by GNTurbo6 View Post
    Well, there's a product in Big Lots (or used to be, I don't bother with the car) called Street Level Oil Boost (SLOB) that had a huge dose of ZDDP, and there's another at PEP and by order from Napa called Valvoline Sythetic Oil Treatment. It's loaded with Moly and ZDDP. It was meant for just this situation with flat tappets in American V-8s from the API SJ-era. Some guys use it in their DOHC Hondas and whatnot, but it's not necessary in DOHCs from Japan, those engines, unless "riced out" get along fine on SM. The Valvoline being loaded with Moly, I dunno if that would be good for a clutch, even if the zinc would be good for the trannie.
    Sounds like a good diesel HDEO is the way to go. Tx!
    I93/495
    Quote Originally Posted by Stiggy View Post
    Uh oh, oil thread.
    good shit
    live to ride seth399's Avatar
    Feb 2007
    CA
    Amsoil as well in my truck and bikes...though I use Honda HP tranny fluid as well in dirtbikes
    LRRS #399
    MX #505
    Lifer a13x's Avatar
    May 2005
    Warner Springs, CA
    Honda Pro GN4
    Boston --> San Diego
  1. Where to get zinc dichromate plating done?
    By number9 in forum General Bike Related
    Last Post: 12-05-12, 10:26 AM
