Results 1 to 4 of 4
Sv650 oil consumption question
    Aug 2011
    Coventry, RI
    Ok so this is my first year on an sv and i wanted to gauge my oil usage from some experienced sv guys. Its an 08 with around 14k on her. I have done 2 practice days and 3 race rounds and i know im a shitty racer but i never looked at the oil level until last night since the beginning of the season (i know i know i am usually better then that and i only have my own stupidity to blame) but the level has gone from the full line down to just under the low line. Seems like alot of oil for its limited though very hard use. My teammate philkinson is also on an sv this year and has only used a fraction of oil with the same amount of track time. Is this something i should be concerned about? Bike seems to run fine, not smoking, no fluids anywhere they shouldnt be and no leaks.
    LRRS EX #329
    Jun 2012
    RI
    Re: Sv650 oil consumption question
    My secret is to unhook the breather hoses. Doesn't let the oil stay in there long enough to get consumed
    Sent from my SM-G920T using Tapatalk
    642
    quite common for SVs to consume oil during extended higher rpm operation, I used to consume a quart in a 1000 mile SS1k while droning along the highway all day, but routine day to day riding that may have included hooliganism now and then, consumption observed between oil changes was negligible, common wisdom is the the consumption of oil is thru the breather hoses, but the rate so low that not noticeable in the exhaust
    rides bikes
    Nov 2014
    My 2nd gen race SV drank a lot of oil. I always chalked it up to it being broken in on the street (relatively low RPM) and then being used on the track (high RPM). It had good compression, just a difference in seating rings.
    My street SV1k never used any.
  1. question about manual cam tensioner on a gen 2 sv650
    By Mgiossi in forum Bike Maintenance
    Last Post: 10-10-16, 10:14 AM
  2. Newbie Question RE: SV650
    By DroFiveOh in forum General Bike Related
    Last Post: 05-07-12, 08:04 AM
  3. '03 SV650 S (fairing question)
    By McBiggity in forum General Bike Related
    Last Post: 09-12-03, 01:50 PM
