Results 1 to 11 of 11
Do I need to make a hole bigger to use JB weld???
    Newbie noobmike920's Avatar
    May 2010
    Johnson, VT
    Cool Do I need to make a hole bigger to use JB weld???
    the hole i am repairing is only big enough to stap a safty pin through. should i drill it a little bigger so i KNOW that the weld is going to hold??? i was thinking like 1/16 or at the most a 1/8 hole...please help me
    AWSOMENESS
    Re: Do I need to make a hole bigger to use JB weld???
    Quote Originally Posted by noobmike920 View Post
    Where is this hole?
    Lifer obsolete's Avatar
    Norf Sho
    Where is this hole?
    You'll figure that out when you get older.
    -Alex
    Posting Freak idratherberidin's Avatar
    Apr 2008
    Danvers, Ma
    Where is this hole?
    I prefer to use the term "Guide me in"
    Member hskater26's Avatar
    Jonesborough, TN
    thats what she said
    95 Yamaha Seca II- Sold
    02 Ducati ST2
    may i suggest a water based lubricant
    Zip Tie Alley Racing #444
    Signature edit by Tricky mike
    Apr 2008
    Danvers, Ma
    Posting Freak 6 Fingered Man's Avatar
    Feb 2009
    Exeter NH
    Smuttys virginity aside....
    It should hold if you can cover the whole area with J.B. but that depends on where the hole is and what you are trying to acomplish.
    LRRS #951
    My girlfriend wants to be like me when she grows up.
    Sometimes violence IS the answer. The answer every other time is busa.
    May 2010
    Johnson, VT
    it is on my gas tank
    AWSOMENESS
    Feb 2009
    Exeter NH
    I have done this more times than i want to admit...
    Sand the paint off the area so the gas can't get between the paint and the J.B.,Take a small peice of steel, place it over the hole. Then cover the area with J.B. completley so you have "welded" the steel over your hole. That is the best method i have found. If you just J.B. over the hole it can leak.
    LRRS #951
  1. Can anybody weld Ti ?
    By Jim in forum Bike Maintenance
    Last Post: 05-13-13, 05:34 AM
  2. Weld work
    By slammp in forum General Bike Related
    Last Post: 11-11-10, 11:36 AM
  3. More Bigger
    Last Post: 05-14-09, 12:38 AM
  4. Teach me to weld...
    Last Post: 10-07-03, 12:21 PM
