Results 1 to 10 of 10
intermittent spark
    san fran
    intermittent spark
    So i have this 1979 yamaha qt50 scooter. It ran ok up until last week where it died. no spark. Replaced the plug, replaced with generic coil, and still no spark. tonight i threw in a used cdi box and bam spark, but pretty weak. Also after working on it for a while, i find out its intermittent spark. Its getting fuel, and air. compression is great.
    Before i go buying a new coil, this time a yamaha one, would this be the part im looking to fix? if there is something else i should look at i would like to know. ive checked the stator and there is good power coming out of it going into and out of the cdi. battery is fully charged, kick start only.
    maybe the cheapo 15 dollar generic coil was a bad idea?
    Tuono
    Re: intermittent spark
    Could be the pickup?
    Have you cleaned all the grounds?
    Derry NH
    My first thought is the ignition pickup not sending a consistent signal to the CDI.
    san fran
    cleaned all the grounds, by ignition pickup, that would be the wire coming out of the motor from the stator? I had it hooked to a multimeter and it seemed pretty consistent.
    Tuono
    Senior Member FTMS's Avatar
    Warren, NH
    Pick up coil can either be a single wire or 2 wires depending on type. It is general test with a resistance reading.
    2004 Honda VTR
    1998 Honda VTR (Track Bike )
    1990 Honda CB-1
    1973 Yamaha RD350
    http://www.ftmsnh.com
    Derry NH
    Usually the opposite side of the motor from the stator.
    Dec 2005
    Near The Dragon
    With intermittent spark you'll get intermittent test readings. Which is to say that you cannot trust your reading now to indicate what's going on when it's pitching a fit.
    Weak or intermittent spark can be caused by a few things, but I'd start at the points/pickup coil/air gap/ground.
    Hate to say it, but when plugged in the other cdi box and it fired up, that was the most pertinent diagnostic indication. Meaning you likely need a new cdi, but while you are there, a proper coil that the cdi is designed to power is a good idea.
    Get out while you can
    Find your own path
    Dec 2005
    Near The Dragon
    Hang on a sec.. An friggin 1979 bike was running electronic ignition?
    I would have bet money that was a points system....
    Find your own path
    It's simply the sparkplug wire. Change that out, fill up the cap with dielectric grease, pop it on the sparkplug and you're good. Cheap, fixed, good...
    san fran
    Quote Originally Posted by Cerberus View Post
    no points here, its a cdi system, and while we're at it, shaft drive, and single sided swing arm!
    Tuono
  1. Intermittent electrical power loss to no power at all
    By bmx9854 in forum Bike Maintenance
    Last Post: 07-08-15, 09:30 AM
  2. No spark help
    By shortbus in forum Bike Maintenance
    Last Post: 10-08-12, 12:06 PM
  3. No spark?
    Last Post: 07-29-07, 01:28 PM
  4. spark plugs
    By oreo_n2 in forum General Bike Related
    Last Post: 04-14-03, 07:32 PM
