Results 1 to 10 of 10
shock remove/install
    May 2011
    Northern MA
    My first time fiddling with the shock. Does this sound like the shock will be easy to remove/install:
    - lift bike with rear stand
    - remove rear wheel
    - use jack stands to support bike from rear sets
    Lifer Imbeek's Avatar
    Sep 2012
    Southwick,MA
    Re: shock remove/install
    That should work. Some people who have folding foot pegs flip them upside down for this same operation, so they will support the weight without folding. With fixed rear sets that don't fold, no need to flip em.
    Depending on the bike/bodywork, sometimes you can remove the subframe and/or leave the wheel on
    What Bike?
    May 2011
    Northern MA
    Thanks Imbeek
    What Bike?
    Daytona 675
    Also..a ladder with staps to take the weight off the back wheel. Allows you to drop the shock/swing arm down
    Lifer SwiftTone's Avatar
    Norwood, MA
    Flipping the pegs is how I do it. Done it 5 times this way
    Lifer jasnmar's Avatar
    Mar 2012
    Chichester, NH
    Yeah, I just tossed some rachet straps over some of the lower rafter members and hooked them to the frame. Put the swing arm on the rear stand. Take note of where the garage door opens
    Lifer gixxer72's Avatar
    The desert
    I've used a length of steel rod through the swing arm pivot bolt and jack stands under it. 2 person job though, 1 to lift and 1 to place stands. The 5 gallon pail works on the light machines!
    Attached Thumbnails Attached Thumbnails shock remove/install-image-jpg
    Look on YouTube, there can be some "gotchas."
    Lifer Falko's Avatar
    MoonTown
    YEars ago I built a small lift for this. Has a trailer winch mounted on a cross bar to lift the bike, worked really well. I was able to lift my FJR completely off the ground. I've seen people do the same using 1" steel pipe and a ratchet strap. I was a little weary of the strength of that contraption so I went with 2x2x3/16 steel tubing uprights and 3" c-channel cross member.
  1. How to remove frozen axle
    Last Post: 12-20-19, 07:16 AM
  2. How to remove mirrors
    By dingley00 in forum General Bike Related
    Last Post: 06-17-13, 07:48 PM
  3. Remove Tank
    By GixxerK1ng in forum General Bike Related
    Last Post: 08-21-08, 11:08 AM
