The radiator on my old K100 started leaking this weekend. I saw an old thread (2012?) on the topic but that didn't give me much confidence in any of the shops mentioned. Does anyone have experience with a local (Lowell/Nashua) area shop to get it fixed? I can get a new Chinese replica for <$200 but won't get it for months and quality is unknown. So repairing it seems to be the better option.
DanG
- Blaise Pascal
Can't speak for locals, but I did send my leaking/bent TL1000S radiator to Myler's Radiators out in Utah. They fixed and straightened it for ~$75, painted it and sent it back within about 2 weeks. Very reasonable cost and it never leaked again.
2023 KTM 890 Adventure R
Lowell Auto Radiator Service Inc
Just cut out the fins around the leak, jb weld, done.
LRRS/CCS #66
That's where I took it. Seems like a good, honest guy. He said there are two likely causes of the leak, one pretty easy to fix & the other unfixable because of the way it was made. I'm also looking at used and new Chinese radiators. Not sure which is the bigger risk.
DanG
- Blaise Pascal
Sounds like you have it figured out, but Rogers Auto Radiator in Medford is awesome.
Update -
I took my radiator to Lowell Auto Radiator Service. Even though it wasn't fixable, I highly recommend him for radiator repairs.
When he first looked at it, he said it probably wasn't fixable because of the unusual way it's put together. He tried a fix and it held for about 20 minutes into the test but then failed.
I ordered a Chinese knockoff ($185 Vs. $850 for a new OEM one). I went that direction mostly because he advised that a used one ($150-$200) would be old and worn and just as likely to fail as mine. It arrived this week, and looks identical except the thermostat is held on by a screw-on cap instead of the stock bolt-on. Fortunately, I took it to Lowell Radiator to be tested before installing it. The cap leaked. A lot. Instead of an o-ring, it shipped with a thin gasket which doesn't work. We spent about an hour trying a few things and it got better but not good enough.
I've ordered a variety of o-rings. The manufacturer says a 51mmx3mm should work so I got that and adjacent sized o-rings in case it wasn't quite right. The manufacturer also suggested plumbing tape on the threads, which seems like a good idea (temp range up to 250C and resistant to petrochemicals). I'd like to hear if anyone thinks that's a dumb idea and why.
The o-rings should arrive tomorrow so I'll go back and test it again. Hopefully between the o-rings and the tape I'll get a good reliable seal.
DanG
- Blaise Pascal
Shit. I got a few of rings and one of them did a decent job sealing the thermostat cover. But that just exposed a tubes to leak. It might be fixable (on a brand-new radiator), but radiator guy says if it leaks out of the box what are the odds of not having more leaks a few months from now?
So, contacting the vendor tonight to see what the options are.
DanG
- Blaise Pascal
