Results 1 to 23 of 23
Learning to Bend Lexan
    Massachusetts' Noth Shoah
    I don't have any metalworking tools or skills, so I've started fooling around with bending some Lexan that I've had around the house. (I use it to close off the space above our air conditioners since our windows all slide horizontally, not vertically.) Lexan is GE's name for polycarbonate plastic sheeting, BTW.
    I got Brenda one of the closeout HP Touchpads, and was really annoyed at having to hold it the entire time I used it. Here's what I did with a scrap piece of Lexan (3/32 thick). I just heated the areas I wanted to bend with a propane torch and then bent them over the edge of the workbench:
    Learning to Bend Lexan-bending-lexan-1-jpg
    Next, I fooled around with an idea for mounting the Droid Razr in the car. You can see where too much heat from the torch caused the moisture in the plastic to cause bubbling when it got too hot.
    Learning to Bend Lexan-bending-lexan-2-jpg
    I wanted to do some brackets to adapt an SV1000S fairing to the upper fairing subframe of an EX500. The shapes were all compound curves, and I figured heating it in a stove would be better than using a torch. However, I couldn't find anything really helpful online. So, I've experimented on my own, and thought somebody might get something of value out of this.
    Here's what I've learned so far. Lexan will bend, barely, at 250°. It'll bend more easily at 275°. At 310°, it bends really easily. At 350°, it becomes like silly putty, but only for about thirty seconds.
    Learning to Bend Lexan-bending-lexan-4-jpg
    So far, I've made three brackets for the EX. They don't look terribly great, but they're strong as heck!
    I've discovered some useful things along the way.
    1.Use insulated gloves. Trust me on this one.
    2.It's helpful to have a pot of cold water nearby for when you forget rule #1.
    3.Going up on the temperature is best done s l o w l y. I spent 2 hours going up from 175° to 350° today to make the last bracket, going up in 25° steps. Even doing 15 minutes at 175° and then jumping right to ten minutes at 250° caused bubbling.
    4.If your wife agrees to let you use the stove, be nice and put down some tin foil on the baking sheet. Move the plastic piece around on the foil every half hour or so, so it won't stick to the foil when you're ready to work with it.
    5.Once you're ready to bend the plastic, you've got a minute or less. Be ready.
    6.Cut broad shapes before heating. This way, when a piece bubbles on you, you won't have wasted 45 minutes crafting that groovy shape you were hoping to have. Cut the finer aspects later. (A rotary tool works fine.)
    7.When you're cutting with a rotary tool, the plastic gets flung out at you, and it's hot. (See rule #2.)
    8.Drilling is best done with the finest bit you've got, and working up.
    Here's how I learned about rule #3.
    Learning to Bend Lexan-bending-lexan-3-jpg
    I'd be interested to hear what others' experiences are. Whatcha got?
    Go fast. Have fun. Repeat.
    Central MA
    Re: Learning to Bend Lexan
    We work with polycarbonate sheeting fairly often, to make guards and machine parts. Rule #1 - bend it cold, if possible. Heat will make (the heated area) brittle.
    How the devil do you bend it cold without snapping?
    Central MA
    Well, we have found that there are differences in the different manufacturers recipes. Are you using *real* Lexan, or generic polycarbonate sheeting? Lexan of 1/8"- 3/16", and sometimes even up to 1/4" should bend without snapping. I will have to ask my guys about any details, but we generally try to avoid heat.
    Central MA
    If you are using acrylic, PVC, or polyethylene, it will snap easily. Polycarbonate sheeting is the only one that bends without heat. We use the others as well, but for different purposes (window replacement, etc.). U.S. Plastics used to have a whole bunch of directions and lists of quality's and uses on their website.
    Yeah, I'm using gen-u-wine Lexan. I'll be looking up U. S. Plastics asap.
    Edit: They pretty much confirmed what I learned on my own.
    Lifer joeswamp's Avatar
    Sep 2006
    Swampscott, MA
    Lexan is weird stuff for sure. It seems hard as glass but when you really stress it it bends like chewing gum.
    Joe
    04 Thruxton (Street)
    01 SV650 (Track)
    I'm going to have to do some more experimenting!
    If you sand the edges but want them smoother, you can wipe them with acetone. Unlike acrylic, if you scratch polycarbonate you can't buff out the scratches.
    We cheat. We have a Stratasys Fortus machine that can make any shape you can design in 3D CAD directly out of Polycarbonate. But's white only, not clear.
    Old and Slow Sheppo's Avatar
    Westford, Ma
    I used to bend it in a sheet metal brake when I was making shit for my race car .
    Posted by Jane in BoxChat
    Central MA
    Yup, that is what we use, Sheppo.
    Central MA
    If you can to sacrifice some strength at the bend, you can scribe it, or partially cut it using a tool that looks like a fish hook, and then bend it easily.
    Feb 2007
    I have used sheets of this to make fairing extensions for winter. You can get it soft in the oven and grab it with ovgloves and bend it to conour from the mirror to the fairing, blocking wind to your hands.
    now i want to make a full set of bodywork for my race bike out of lexan
    Member davemon's Avatar
    Sep 2007
    Bay Area, CA
    I'm now curious as I would really like to make a pair of these:
    http://mts1200.info/mts12_faq/multis...1200_wings.htm
    http://mts1200.info/mts12_faq/multis...king_wings.htm
    This guy used something called Perspex but Lexan would be good too one would think.
    Dave
    Newbie Slowride's Avatar
    Sep 2012
    S.E. Mass.
    Quote Originally Posted by dontpanic View Post
    When I did commercial glass we would make lexan windscreens for bikes, we would basically use a round object at first to get the initial bend going (keep in mind slower is better). Then we would make a wooden frame jig for the shape we wanted and c-clamp it into place.
    Quote Originally Posted by davemon View Post
    /This guy used something called Perspex but Lexan would be good too one would think.
    Dave
    Perspex is acrylic, AKA Plexiglass, Lucite etc. PC would be a better choice due to better impact resistance.
    Note that you can "line bend" PC with heat as is done with acrylic if you don't have a brake.
    Wife calls me a member Svenny's Avatar
    Mar 2012
    Seekonk MA
    Perspex is the UK name for Plexiglass or Lucite, an acrylic material, and is not as impact resistant as Lexan, which is polycarbonate. Acrylic will snap if you try and bend it cold (like in a sheet metal brake). Polycarbonate can be cold formed in a brake, but will retain it's bend better if heat is used. Slow, even heat is important to avoid the bubbles. I may have some scrap pieces (12x12 and smaller) sitting around in my shop if someone needs some smaller pieces to mess around with...it'll either be 3mm or 6mm thick...I'll take a look for it later today.
    2008 Fisher-Price Kawi 12VDC
    Exide hi-performance battery
    Frost-King duct tape reinforced steering damper
    Topps "Garbage Pail Kids" custom graphics
    Mar 2012
    Seekonk MA
    COLD FORMING
    A bend in Plaskolite acrylic sheet can be accomplished without applying heat. A minimum radius of 200 times the thickness of the acrylic is required to avoid stress cracking.
    Lifer Stromper's Avatar
    Eastern Ct
    When I did thicker stuff I would run a saw a 1/4 to 1/3 through and then it would ben in a nice straight line.
    The calculus of hate
    Feb 2007
    Dont know about you guys but here in the City I can get 1ft squares to practice with at plastic shops. You put it in the oven at like 190 & keep testing till its flexible/floppy. You hold it in shape while your girl sprays it with water to harden it.
    Fun for the whole family
    Junior Member hdscarbro's Avatar
    NW Boston
    I made a windscreen for my SRX250 from Vivak. Here are some photos:
    https://picasaweb.google.com/hdscarb...eat=directlink
    Now THAT is very cool....
  1. Replies: 1
    Last Post: 06-17-11, 06:20 AM
  2. Learning to fly
    By rebelpacket in forum Dirty Bastards
    Last Post: 10-16-07, 07:33 AM
  3. learning
    By igneous in forum General Bike Related
    Last Post: 04-25-02, 09:39 PM
