Results 1 to 21 of 21
Loctite on Sprocket bolts?
    Posting Freak idratherberidin's Avatar
    Apr 2008
    Danvers, Ma
    Do you use it on front and rear, or at all? and what color? Thanks
    Re: Loctite on Sprocket bolts?
    YES on just about everything.
    Blue at a min.
    green as a max
    I use Blue and Puple for light duty........
    KB KB's Avatar
    Manchester NH
    I don't use it on anything.
    LRRS/CCS EX #13
    GMD COMPUTRACK
    For a race bike? No need except for rearsets.
    on my street bike, low strength on everything.
    KB KB's Avatar
    Manchester NH
    Nah not even on the racebike.
    LRRS/CCS EX #13
    GMD COMPUTRACK
    Worcester, MA
    But I also would do my rotor bolts on the race bike. generally i always used blue.
    LRRS EX #165 (formerly)
    Apr 2008
    Danvers, Ma
    Thanks guys. I found a lot of mixed info so I wanted to ask. I'll be installing my new Stealth Sprocket set up this weekend.
    I had 2 sprocket bolts loosen up on me. I was cleaning up some chain lube and was shocked to find one backed out a little and another was not near torque spec. From then on they see the Loc.
    I facked a swingarm by not locktiting the sprocket bolts on my racebike. I think the chain came off also.
    Definitely blue locktite at least. It's hard to figure out what the hell is going on when those puppies back out.
    live to ride seth399's Avatar
    Feb 2007
    CA
    I just put red loctite on those and rotor bolts etc
    LRRS #399
    MX #505
    Nov 2007
    I don't think I put loctite on the cush studs, but then again the sprocket nuts on my bike are locknuts...
    Zip-Tie Alley Racing
    LRRS/CCS #103
    May 2007
    Southern NH
    No...but thinking I will now....
    great question
    (am I confused or have I seen some of these actually safety wired?)
    Muhammad Ali.
    I safety the front sprocket. It has 2 bolts that usually no taper to them. Ease of drilling.
    My rear has taper to the bolts so not as easy to drill. + you would eat up a lot of safty wire and time making sure every thing is just right.
    Lifer richw's Avatar
    Aug 2004
    Baltic,CT
    All my fronts had bend over safety tab so no
    Otherwise yes I recommend it
    Glen Beck is John the Baptist
    Feb 2007
    CA
    safety wire on the rear bolts? geez, might as well safety wire the gas cap to tank and wire the tires to rims
    LRRS #399
    MX #505
    KB KB's Avatar
    Manchester NH
    I actually lied I do use loctite on the countershaft sprocket.
    LRRS/CCS EX #13
    GMD COMPUTRACK
    Lifer lrrs313's Avatar
    Asheville, NC
    You been taking pages out of 428's repair manual?
    Member out thumped's Avatar
    Dec 2006
    VT
    I know red loctite is called for on sprockets on dirt bikes. Once they come loose you can throw them out as they will never stay tight again. They get ruined in a hurry. Same goes for a shift bolt, but i only use blue on thet.
    OT
    It pays to play.
    Ride fast,
    You will get farther before it is over!
    Lifer TIMMYDUCK's Avatar
    Feb 2003
    The 14th State Vermont
    Quote Originally Posted by idratherberidin View Post
    I reccommend using a torgue wrench and applying the proper foot pounds of torgue as shown in your service manual, but that's just me.
    And adding a little light duty loc-tite to each bolt couldn't hurt either.
    TIMMYDUCK
    KB KB's Avatar
    Manchester NH
    Quote Originally Posted by lrrs313 View Post
    He has a manual?
    I got a guy in manch that is my manual. Cheap too!!!
    LRRS/CCS EX #13
    GMD COMPUTRACK
  1. Loctite 648? Anyone have? Suitable substitute?
    By Garrett in forum General Bike Related
    Last Post: 02-13-14, 09:39 PM
  2. Changing Handelbars/Red Loctite...
    By aweesner in forum Bike Maintenance
    Last Post: 08-03-12, 05:25 PM
  3. ALOC bolts??
    By The Snowman in forum Bike Maintenance
    Last Post: 08-29-08, 10:48 PM
  4. bolts
    By Wishbone in forum General Bike Related
    Last Post: 03-29-07, 09:38 PM
