Page 1 of 3 123 LastLast
Results 1 to 25 of 53
Motorcycle Repair Course
    May 2012
    I want to learn how to do more work on my bike.
    Are there any classes in the area like this one?
    Lifer ilikenapalm's Avatar
    Connecticut
    Re: Motorcycle Repair Course
    $1,500 for a class? Fuck that.
    Buy something broken, get a repair manual, and dive in.
    Youtube has great content on it for almost everything you would need to do to a bike.
    Spend that money on tools and a repair manual.
    I know Seacoast does seminars.....
    Lifer Dip Dungles's Avatar
    Chilling with Dick Hurts
    That they do. Very informative although within 20 minutes into the suspension course I figured out that if any work needs to be done to my bike I would be calling PK
    Shannon
    Wirelessly posted
    I could run a basic maintenance ( up to valve adjustments) course at my house for 5-10 people for short money (for refreshments, materials etc). Any interest?
    May 2011
    Lincoln,RI
    Wirelessly posted
    In
    May 2012
    Yes, I've done the seacoast seminars. very helpful but am looking for something more hands on now.
    Wirelessly posted
    Yes, count me in Degsy.
    May 2012
    Quote Originally Posted by imstuner View Post
    I have done that. I don't have much of a mechanical background and have found that having someone to help when I'm stuck or showing me tricks that are not in the manual make everything easier.
    I feel much better working through issues on my car but I want to make sure I don't make any mistakes on my track bike as hurting myself, or worse others, because of something I missed is my concern.
    Lifer SwiftTone's Avatar
    Norwood, MA
    Wirelessly posted
    In also.
    I've think I know what I'm doing but next have a lot of confidence. My wheel or suspension hasn't fallen off so far though
    Lifer Billy's Avatar
    Feb 2006
    Metro West, MA
    Like others have said buy a repair manual, tools and have a computer to search youtube/forums. I have yet to need a dealership for repairs. Only things I dont do is tire replacements and suspension work.
    Perfect recent example was the drive shaft (shaft the front sprocket goes on) oil seal started leaking on my 06 GSXR. I had no freaking clue on what I needed to do. Couple hours of research (repair manual, youtube, forums) and had the bad one out, and the new one in.
    May 2012
    Thanks Gino, but I'm looking for an inexpensive community college course not a professional mechanics school.
    Maybe you can do a workshop like Degsy...I know you have the skills
    Wirelessly posted
    I was hoping Geno and a couple of others might come over and help instruct :-) geno doesnt live far away.
    Member daisha's Avatar
    Norwood, MA
    Wirelessly posted
    I'd be interested.
    I am in as long as I can release the Kraken Motorcycle Repair Course-kraken-jpg
    Shannon
    if it is other than a Hawk forget about it.
    i'm pretty good at taking things apart. Putting them back together takes a lil longer
    but will work for
    or
    Wirelessly posted
    sweet. i have a bike that needs the valves checked
    May 2012
    but will work for
    or
    I'll get you a bottle of this...
    Motorcycle Repair Course-images-jpg
    much better than that cheap stuff you drink
    Wirelessly posted
    Quote Originally Posted by Jimmy Faceplant
    Wirelessly posted
    Perfect. An inline 4 is the most common bike and it would have to be a bike that was not ridden in, as it needs to be at ambient temp for valves adjustments.
    Wirelessly posted
    I could be in for this! To learn that is... I need to get into my 929..
    Wirelessly posted
    List of topics. Add anything you would specifically like to learn.
    Oil/filter change
    Air filter check
    Chain and sprocket install
    Wheel removal
    Fork removal (no fork internal stuff, ill leave that to PK)
    Valve check/adjustment
    Clutch replacement
    FI code diagnosis
    Carb removal/clean
    Brake pad/line change and brake bleed
    Coolant drain and flush/fill.
    Exhaust removal/install.
    Shock removal/install
    Swingarm removal/install.
    Tire swap
    Basic charging system.
    Onviously, getting to all of that in one day would be impossible, even with 3 "instructors" so we would have to decide what to focus on.
    This is what I am looking for. You the man Degs.
    Shannon
    might I suggest a lesson on
    stuck fastener removal, what tool to use for the job, when to stop before you bugger stuff worse, when to used hand impact, heat, etc
    Apr 2011
    Rockland
    I would also be interested in this, specially
    Wheel removal
    Clutch replacement
    Did you have time/day of the week in mind?
    Wirelessly posted
    Oil/filter change
    Air filter check
    Wheel removal
    Clutch replacement
    FI code diagnosis
    Carb removal/clean
    Tire swap
  1. Motorcycle gear repair
    Last Post: 04-15-10, 06:54 PM
  2. Motorcycle Repair
    By LODScubaSteve in forum General Bike Related
    Last Post: 09-10-09, 10:24 PM
  3. Motorcycle Repair
    By cnirmal in forum Bike Maintenance
    Last Post: 06-14-08, 01:07 PM
  4. Motorcycle repair
    By capt1014 in forum Bike Maintenance
    Last Post: 01-14-07, 01:29 PM
