Results 1 to 25 of 31
Low speed stability?
    beige camry attack mojobreakfast's Avatar
    Salem, MA
    I don't know if this is my imagination or not, and I can't find anything really relevant on Google, so here goes.
    I get the distinct feeling that the low speed stability of my bike has been gradually declining. That is, very low speed, stop and go type traffic stuff where the bike feels more wobbly than when I first got it and also, in low speed corners (turning into parking spaces) the front wheel seems to want to "fall in" more than it used to.
    My bike is minty fresh and runs great otherwise, never dropped, crashed, abused, curbed, wheelied.. absolutely nothing squidly-diddly... showroom mint. The only thing different between when I bought it last year and now, is the bike has 5600 miles and a flat area on the center of the rear tire tread (I slab commute on the bike).
    Just my imagination? Tire wear? Just want to know if there is some secret motorcycle mojo I haven't been clued into yet.
    no bikes currently
    Wirelessly posted (BlackBerry8330/4.5.0.160 Profile/MIDP-2.0 Configuration/CLDC-1.1 VendorID/105)
    Tire pressure or tires.
    Just Registered Doc's Avatar
    Jericho, VT
    Re: Low speed stability?
    Salem, MA
    I check the pressure pretty often but will look at it in the morning. If it's not the pressure, it could be general tire wear? Are there fairly noticeable handling changes as tires wear, even in ordinary street riding?
    no bikes currently
    Lifer lrrs313's Avatar
    Asheville, NC
    Quote Originally Posted by mojobreakfast View Post
    Yes. The "falling into turns" you're feeling is the bike leaning past the flat spot. Not usually really noticeable as the wear occurs, but when you put on a fresh set of tires, you'll notice a big difference.
    Senior Member palanon's Avatar
    Nov 2008
    Epsom, New Hampshire
    Tires are the first thing. Besides pressure or scalloping, did you change the front to a higher profile tire?
    If none of the above, I'd bet you need to tighten the head bearings.That slotted nut under your top triple.
    " In the name of the Spedo, the Tach and the Holy Throttle, Amen. "
    Boston Moto trackdays will help correct any and all tire wear issues.
    <---- R.I.P. Hauptman's Avatar
    Pepperell, MA
    tire wear fo sho
    08 SV650s = brokenz
    Beantown Stan's Avatar
    Needham, MA
    Most likely tire pressure.. It happened to me, I was low in the front pumped it up felt much better.
    Mike (Stan) Facebook username = MJStanley508
    2006 Suzuki GSXR 600
    Yoshi R-55 Slip-on, PUIG rear hugger, PUIG windscreen, Pazzo levers, 6k HID kit
    Nov 2004
    Boston, MA
    Dont go slow.
    EVERYTHING is a repost
    06 749R #0047
    08 R 1200 GSA
    13 Monster EVO 1100
    Lifer akira700's Avatar
    Apr 2005
    in the city
    Dont go slow.
    Good one!
    2008 Honda CBR 600RR
    Salem, MA
    Quote Originally Posted by lrrs313 View Post
    Cool. Thanks. I was hoping to milk the tires a little while longer, especially since I'm not a particularly hard rider, mostly a commuter and weekend leisure rides. But this stability issue is disconcerting enough to probably change them out at this point.
    To answer the other questions.. tires have never been changed out, they are factory. And, as much as I would like to not have to go slow, sometimes reality intervenes.
    Track days.. next year. Still learning (and broke).
    no bikes currently
    wouldnt be anything with the stock damper, right?
    Jack Wagon hefdukes23's Avatar
    Portland, ME
    Dont go slow.
    "When in doubt - gas it. It'll either fix the problem or end the suspense!"
    07 Triumph Daytona 675
    04 Suzuki GSX-R 600
    Salem, MA
    Quote Originally Posted by DBKromz View Post
    Interesting thought, and makes me kind of neurotic because come to think of it the twitchy low speed handling does remind me somewhat of my first bike, which did not have one - though on the Honda there is a lamp on the instrument cluster that is supposed to illuminate if there is a problem with it, but all seems fine.
    I was also under the impression that the action of the system is progressive and dependent on input from speed sensor(s) (or the ECU - engine speed?), therefore normally it would not really be a factor in low speed stability. Could be wrong on that though. I'll keep it in mind but first thing I'm going to look at is tire pressure.
    It's not bad enough to be a critical situation, but being a relatively new rider thought it was interesting and probably something worth researching and learning about. I'm hoping its just the tires.
    no bikes currently
    Jim is so cute when he's trying to play mechanic.
    Sweet jesus save us
    Lifer DaSarge's Avatar
    Oct 2002
    Cape Cod
    Sweet jesus save us
    I Void Warranties LowSider's Avatar
    Jul 2005
    Quote Originally Posted by palanon View Post
    That's what my mind went to. In 5k miles on a new bike the bearings could have became a little loose. When you install new bearings you want to double check they did not loosen after a short period of time- they usually do. That will make the bars want to fall to the steering stops at low speeds.
    You can check this by raising the front end (not with a front stand- you do not want the tripple tree to have any resistance) and see how easily the bars move from steering stop to stop. If you let go of the bars and it falls to one side and bounces off the stop, it is too loose. You want it to just fall on the stop and not bounce.
    Dec 2003
    Ma
    Too many 'cooks'....
    Sep 2006
    Around the corner
    Doood your bike is junk and unfixable. sell it to me cheap and buy something that will not break down so quickly like a TANK wit steel tracks. you could commute for 100's of years on those babies.
    The rule is:
    Lifer Wishbone's Avatar
    Jul 2006
    To many people preparing lunch will affect my low speed handling?
    ...go on
    Quote Originally Posted by Wishbone
    ...go on
    Not enough waitresses.
    Sep 2006
    Around the corner
    orrrrr Sammiches ... gonna get me a sammich now
    The rule is:
    Jul 2006
    Quote Originally Posted by The Crashing Tomato View Post
    I might be on the right track. But I had cheerios for breakfast. Will this affect my high speed handling?
  1. Mandated ABS and stability control for all motorcycles
    By oVTo in forum General Bike Related
    Last Post: 09-18-18, 08:00 AM
  2. Stability Issue on Ducati Multistrada
    By NHBusa in forum General Bike Related
    Last Post: 08-05-18, 08:52 AM
  3. Did Speed do something right??
    By BMFR6 in forum Pit Area
    Last Post: 02-20-09, 11:30 AM
