here's the thing, if the head was loose and the engine ran that way for any amount of time, the head seal (gasket/head/cylinder deck surface) was almost certainly damaged by high temperature gas erosion, so just re torquing it won't fix it.
i have seen the oil trick bump 20-30 psi compression pressures to 80 or 90 psi
Get out while you can
Find your own path
update?
Find your own path
