you lubed your brake cable??? what are you riding, a huffy?
but to answer your question, clutch and throttle cables.
LRRS EX #165 (formerly)
i should have quoted it. doh.
I removed my throttle tube, cleaned off the gunk that had built up over the years and applied a thin film of GP grease. Instant throttle when combined with the cable lube.
Now if only the engine would respond as quickly.
Check out my eBay store!
Dave - Motorace - Michelin
Jim, you suck.
There's like 2 cables on the bike, just fucking lube all of them
Then clean your chain again.
Zip-Tie Alley Racing
LRRS/CCS #103
hurray, strikethrough!
What about the speedometer cable. My last speedometer cable broke. I got a new one but I just installed it. Its still not working. Do I need to Lube it? How do I lube it? Sorry for such a naive question. But I thought All I had to do was screw the two ends to at the wheel and on the speedometer. Its not working.
Did I screw up this cable too?
Sold: 1999 Kawasaki ZX-7R
2005 Pulsar 180 DTSi
Owning: Pulsar 220 DTSi
http://www.dhairyagupta.com
http://bostonbiker.blogspot.com
I think I will have to get some grease then. Also there is a pin at the wheel end of the cable with a little slot and I put the slot in correctly. However the pin is not soldered to the cable. It actually came off whe I was installing it hte first time. I have tried to tighten it as much as I could and now it does not come off but just wondering if the cable is still good.
