Results 1 to 25 of 26
lubing cables
    Question lubing cables
    I know many of you already lube your clutch cable, which I finally just did yesterday. But I'm wondering if you guys lube your throttle cable and/or any other cables. thanks.
    Worcester, MA
    Re: lubing cables
    you lubed your brake cable??? what are you riding, a huffy?
    but to answer your question, clutch and throttle cables.
    LRRS EX #165 (formerly)
    Re: lubing cables
    i fixed it. i am an idiot. i meant clutch cable
    Worcester, MA
    Re: lubing cables
    i should have quoted it. doh.
    Senior Member MattyC's Avatar
    Apr 2008
    South Shore, MA
    Re: lubing cables
    Jim, you should have just called me, I have the exact same kit as you do I would have shown you what to do. You could have done both of our bikes
    Re: lubing cables
    matty, already did the clutch cable yesterday. wasnt asking HOW do do it, but what other cables do people lube on their bikes. but thanks for the offer on having me work on your bike for you
    Sep 2007
    Middlebury VT
    Re: lubing cables
    I removed my throttle tube, cleaned off the gunk that had built up over the years and applied a thin film of GP grease. Instant throttle when combined with the cable lube.
    Now if only the engine would respond as quickly.
    Lifer Karaya One's Avatar
    Springfield, Mass
    Re: lubing cables
    Quote Originally Posted by BMFR6 View Post
    POST OF THE WEEK!!!!
    Check out my eBay store!
    Dave - Motorace - Michelin
    Apr 2008
    South Shore, MA
    Re: lubing cables
    oh, I was hoping you would do my dirt and street bike, along with yours.
    Practice makes perfect.
    Re: lubing cables
    what are you ridin that you lube your clutch cable ?
    most oem cables are teflon coated and do not require lube, it is in fact bad to lube them
    but you do need to lube the pivots
    Jul 2006
    Hollis, NH
    Re: lubing cables
    So, instead of joining the ride you planned, you want to lube your cable. I suggest you dip it twice in your vag then maybe think about actually riding that garage queen ...
    Nov 2007
    Re: lubing cables
    Jim, you suck.
    There's like 2 cables on the bike, just fucking lube all of them
    Then clean your chain again.
    Zip-Tie Alley Racing
    LRRS/CCS #103
    Re: lubing cables
    02 gixxah
    Quote Originally Posted by Cheese-GSXR View Post
    no i had a family thing i had to go to. i lubed the cable on saturday
    Southern, NH
    Re: lubing cables
    That would make the chain gritty and sandy
    Expatriated to Seoul spicy's Avatar
    Reading-> 서올특별시 강남구
    Re: lubing cables
    hurray, strikethrough!
    The Fastest Indian! kamikaze's Avatar
    Jul 2008
    Delhi, Indiaaahh!
    Re: lubing cables
    What about the speedometer cable. My last speedometer cable broke. I got a new one but I just installed it. Its still not working. Do I need to Lube it? How do I lube it? Sorry for such a naive question. But I thought All I had to do was screw the two ends to at the wheel and on the speedometer. Its not working.
    Did I screw up this cable too?
    Sold: 1999 Kawasaki ZX-7R
    2005 Pulsar 180 DTSi
    Owning: Pulsar 220 DTSi
    http://www.dhairyagupta.com
    http://bostonbiker.blogspot.com
    Member garath's Avatar
    Wallingford, CT
    Re: lubing cables
    Quote Originally Posted by kamikaze View Post
    You do need to lube the cable where it connects at the wheel as far as I know.
    Jul 2008
    Delhi, Indiaaahh!
    Re: lubing cables
    Quote Originally Posted by garath View Post
    I think I will have to get some grease then. Also there is a pin at the wheel end of the cable with a little slot and I put the slot in correctly. However the pin is not soldered to the cable. It actually came off whe I was installing it hte first time. I have tried to tighten it as much as I could and now it does not come off but just wondering if the cable is still good.
    Wallingford, CT
    Re: lubing cables
    At least for my old ex500, that pin isn't supposed to come off. I haven't had to do anything with my 9r for that yet so not sure if the cable is the same. But if it is the same, then that is why your cable isn't working.
    Tucson, AZ
    Re: lubing cables
    +1 Sounds like a defective cable to me. I replaced the 250's and never had any issue. The pin shouldnt come out.
    Original
    Jul 2008
    Delhi, Indiaaahh!
    Re: lubing cables
    Quote Originally Posted by jnm988 View Post
    Its a new Cable!
    Re: lubing cables
    02 gixxah
    the budget SV650 has a teflon coated cable since their inception in 99, I find it had to believe that the 02 gsxr doesn't
    Re: lubing cables
    kawasucki still uses mechanical speedo cables ?
    Jul 2008
    Delhi, Indiaaahh!
    Re: lubing cables
    Mine is a '99 model. I am sure all bikes that time used a Mechanical Cable.
    Tucson, AZ
    Re: lubing cables
    No idea if mine is mechanical or not. My 250 is an '03 and definitely has one, but its a 250.
    Original
  1. Lubing the shaft/inner tube change....on a 98 vstar 650
    By Llyodchristmiss in forum Bike Maintenance
    Last Post: 09-16-15, 12:07 PM
  2. USB 2.0 cables
    Last Post: 02-24-11, 11:58 AM
  3. Help with throttle cables
    By JonT in forum General Bike Related
    Last Post: 05-23-10, 08:17 PM
  4. Cables???
    By gixxer6 in forum Bike Maintenance
    Last Post: 01-14-04, 11:35 AM
