Results 26 to 50 of 53
Motorcycle Repair Course
    Dec 2011
    Marlboro
    Re: Motorcycle Repair Course
    I'm in for this. I don't think I've actually met most of the people talking about it and that'd be worth the time right there .
    Wirelessly posted
    Quote Originally Posted by 7UPyours
    I would also be interested in this, specially
    Chain and sprocket install
    Wheel removal
    Fork removal (no fork internal stuff, ill leave that to PK)
    Valve check/adjustment
    Clutch replacement
    Coolant drain and flush/fill.
    Shock removal/install
    Did you have time/day of the week in mind?
    Wirelessly posted
    List of topics. Add anything you would specifically like to learn.
    Oil/filter change
    Air filter check
    Wheel removal
    Clutch replacement
    FI code diagnosis
    Carb removal/clean
    Brake pad/line change and brake bleed
    Exhaust removal/install.
    Swingarm removal/install.
    Tire swap
    Basic charging system.
    Onviously, getting to all of that in one day would be impossible, even with 3 "instructors" so we would have to decide what to focus on.
    I think a saturday or sunday. Start at 9am.
    Back on 2 wheels yay StrayNut's Avatar
    Aug 2011
    NW Boston burbs
    I'm definitely interested! And can pay with alcohols or gift certificates or cash.
    Particularly:
    Fork removal
    Clutch replacement
    To the OP... give it a couple of months and you'll have to swing by the garage in Waltham once it's done. Usually have a few bikes apart at any given time, and only the worst situations require the Degsy bat signal (huge bottle of rum).
    CCS/LRRS #83
    Wirelessly posted
    Safety wiring?
    Blinker fluid?
    Go fast. Have fun. Repeat.
    Aug 2011
    NW Boston burbs
    Slowness removal?
    Derry NH
    I'd be down to help out.
    Please demonstrate the difference between a Craftsman 'phillips' driver and a JIS driver.
    Wirelessly posted
    The inside edge between the tangs on a JIS screw bit is a more square shape. The tangs are also fatter and uniform from top to bottom on a JIS. On a phillips, they are thinner and taper down.
    May 2011
    Holyoke, MA
    might I suggest a lesson on
    stuck fastener removal, what tool to use for the job, when to stop before you bugger stuff worse, when to used hand impact, heat, etc
    ^^This. It is the only mechanical skill that still sometimes escapes me. I have spent hours on a single bolt. I have no issue rebuilding an engine or transmission in a bike or car or boat though.
    To the OP the best mechanical skill is confidance. Get a bike for $500 and rebuild it from the ground up. By the time ur done you will probably be into it for $1000-$1500 and have a more valueable bike and probably be an expert on that bike at least. And if you screw something ip rember it was only a $500 bike.
    Nov 2007
    My R6 probably needs a valve check... I'll come down and drink / watch you do it
    Zip-Tie Alley Racing
    LRRS/CCS #103
    Wirelessly posted
    Quote Originally Posted by CEO
    Cool.
    Nov 2007
    Yeah no use doing jim's he'll just chuck it through a fence or into a wall...
    LRRS/CCS #103
    ...a JIS screw bit is a more square shape.
    Right. Show everyone the dot on the screw heads. Shake the right driver in their faces and tell 'em to invest in a set of the right drivers.
    Tired of buying used motorcycles with rounded out screw heads.
    Wirelessly posted
    Quote Originally Posted by nhbubba
    Haha. The bottom of carbs?
    Ill do one better. Everyone who attends will get a set of JIS drivers.
    No, it's for my street bike. It's got 33k on the speedo and never have checked the valves.
    Carb boot retainers on my current wreck.. but yeah, pretty much you name it.
    Hey now...
    Fer serious though. Where do you source your drivers? I finally broke down and mail ordered a nice set off the 'net. Now I need some for my 'track day' kit.. and so on.
    Daily Commuter Drewski's Avatar
    Apr 2010
    Haverhill, MA
    Wirelessly posted
    I could run a basic maintenance ( up to valve adjustments) course at my house for 5-10 people for short money (for refreshments, materials etc). Any interest?
    very interested.....
    Wirelessly posted
    Quote Originally Posted by Degsy
    Hey now...
    Shhhhh
    Harbor freight.
    Scratch that. They dont carry them any more.
    Amazon.com.
  21. #46
    FUCK OFF Hardcore's Avatar
    Jul 2005
    norwood ma
    Wirelessly posted
    Oil/filter change
    Air filter check
    Wheel removal
    Clutch replacement
    FI code diagnosis
    Carb removal/clean
    Tire swap
    how do u swap out the winter air for summer air without tire removal?
    Amazon.com.
    You know, I never thought to look there. Turns out the best option is the place I bought direct from just advertising on Amazon.
    In for learning how to do a valve check...
    Would be fun to do it all as a practical lesson on our own bikes...
    And yes I know that doing all this requires a) tools b) materials.
    Perhaps a materials and tools list for us?
    Senior Member AVI8_636's Avatar
    Jun 2012
    NH Seacoast
    This actually sounds pretty awesome. If I'm not working I would def be down for a repair workshop.
    2006 DRZ400SM
  25. #50
    Old and Slow Sheppo's Avatar
    Westford, Ma
    I could use a course in FI codes and trouble shooting that. I'm in for that portion.
    Posted by Jane in BoxChat
  1. Motorcycle gear repair
    Last Post: 04-15-10, 06:54 PM
  2. Motorcycle Repair
    By LODScubaSteve in forum General Bike Related
    Last Post: 09-10-09, 10:24 PM
  3. Motorcycle Repair
    By cnirmal in forum Bike Maintenance
    Last Post: 06-14-08, 01:07 PM
  4. Motorcycle repair
    By capt1014 in forum Bike Maintenance
    Last Post: 01-14-07, 01:29 PM
