Anyone in Western MA have the tool to remove an axle from a 2003 636?
It's a 22mm hex, I guess a spark plug remover would do the trick, but I couldn't find one at any of the three stores I went to.
Sears carries nothing that can help, neither does Ace. Valley Motorsports can do the tire install for 70ish I think he said.
Anyways, I'm in Amherst - if anyone can help, please shoot me a PM or post here.
22mm Hex? You mean a 22mm allen? I've got one I could mail you...
sorry, yes.
i would, but then i would just have my father e-mail me the spark plug remover instead (probably much lighter)
i was hoping someone local would have one i could use just for the day
thanks anyways though!
i got a huge azz alen key for my front wheal, think its a 22? not sure. fits a 02 fz1 and you can use it if its the one. im in worcester
Good ole Kawasaki...STILL making bikes with the 22mm allen. I've got one but it's in Peabody...I am in Newton...and you're in Canton. I actually forget where I got mine...perhaps Metric Tool and Screw in Wakefield?!?
'95 ZX7/9
'02 XR650R
'78 KZ1000
I don't get it. I think every rag from Cycle World to Road Racing World has reported this as a big PITA. I sprung for the $30 and bought one years back...but I've never been able to torque it....It's always been....mmmm feels like 75 ft lbs.
'95 ZX7/9
'02 XR650R
'78 KZ1000
The SV is a 12mm hex head.
Yo Bove I'm in Amherst, and I think I have a 22mm allen, I'll check my box in the AM and get back to you
R1
Sears does carry the tools you need. I bought my sparkplug socket setup from them. Look for a half-inch drive sparkplug socket that has a 13/16" hex head on the drive end. Pull the rubber out and make sure the square drive portion is square on the inside of the socket (some are round). Then get a half-inch ratchet extension to put throught he inside of the socket. 13/16" is approximately 21mm which is more than adequate to loosen up the front axle. Since it uses a normal half-inch drive, you can use a torque wrench to tighten it back up.
I can post a picture when I get home.
Just got back from classes and checked, the biggest I have is an 18mm allen key, sorry man![]()
R1
I have the tool. I'm available tomorrow if you want me to drop it off.![]()
If it's anything like my 9R, just leave the pinch bolts tight on the end with the 22mm socket head and loosen them the other end. I think the other end is a 17mm, which is a more readily available tool. Got mine at Ace Hardware.
I've got a 22mm allen... I've seen the reverse spark plug socket setup, but none of the spark plug sockets I found were the right kind.
2003 ZX7R
1995 916
i'm going to check wal mart right now, if they don't have it i'll take you guys up on borrowing it.
thanks
yeah walmart had nothing
would any of you mind lending it to me for a few days? i can meet anywhere - please let me know
thanks
i'm replacing it - got some nice new pilot powers for $235 shipped
i put the rear on 2 days ago
He's all set, came and picked up the tool this afternoon.![]()
