Page 2 of 2 FirstFirst 12
Results 26 to 47 of 47
Nesr r6 wisdom
    Wirelessly posted
    Ou should get it dynod to make sure you don't have a problem that is robbing it of power. At lest you'll have a curve and AF reading. A custom map is the way to go.
    Adrenaline cycles is in Swansea, ma. We use them for our V4 Hondas. They are Dynojet approved and we have also used rob at robs dyno. He's good also but a bit far away from you.
    A custom map will cost you about $300-$350 maximum. Diagnosing problems MIGHT up that price.
    Did you replace the exhaust gaskets with new ones? An exhaust leak or intake leak can cause these type of issues.
    "Plymouth's Fastest" BrianC's Avatar
    Sep 2010
    Plymouth, MA
    Re: Nesr r6 wisdom
    Thanks Degs, I did notice the new air filter didn't seem to sit completely right... maybe that's the intake leak? The gaskets were good so I reused them... no leaking has been observed. I'm about to go out and put the stock filter back in and see what happens.
    LRRS am #121
    Sep 2010
    Plymouth, MA
    Re: Nesr r6 wisdom
    Wasn't the air filter... bike wouldn't idle at all until it reached 145 degrees. Then it starts surging. I've read that there are sometimes issues with throttle position readings on the PC and I notice the readout on te software shows the voltage varying, but the throttle position is 0 when closed. Instructions said not to set the open position because of the ride by wire throttle so that has been left alone at the value that came with the map. So at 0 throttle, the voltage is jumping and when I set the closed position I picked a number right in the middle. The wiring for the PC seems good. I don't know what else to try besides a tune on the dyno so he can set the open throttle voltage when the bike is at the correct rpm and the throttle blades are fully open, but why that would cause a surging idle I can't figure out. I've also read that some people solder the PC wire to the ecu instead of using the provided wire tap, but I'm pretty sure its a good connection there....
    LRRS am #121
    Re: Nesr r6 wisdom
    It may just be lean at idle with the current map, which will make the ecu 'hunt' at idle trying to calm it down. The PC is supposed to read the ECU's trimmed output and adjust it's mapping to match, but based on my ST3 experience the ECU's temp adjustments seemed to get masked by the PC resulting in me needing a spring and summer map set.
    Wirelessly posted
    Make sure you have a VERY good ground for the PCIII. Direct to the battery with a star washer preferably.
    Member THE STUFF 187's Avatar
    SWANSEA MA
    Re: Nesr r6 wisdom
    It is def not the map. Any map off of dyno jets website will allow the bike to idle just fine, might have a flat spot in the mid-upper rpm range . Try disconnecting your power commander to see if that fixs the issue, im sure it will idle fine then. Power commander may have a bad ground or the firmware could need updating, or a bad unit. Only other thing it could be would be air box or block off plates are not sealed completly. 9 out of 10 times its one of the items you touched. but sounds like power commander to me. disconnect it first to elminate that first. Good luck
    Adrenaline Cycle
    Swansea,MA
    Dyno Jet Tuning Center
    Apparel
    Fabrication
    Powder Coating
    Paint
    Service
    Engine service
    Race Bike Prep
    Used OEM Parts
    Track bike rentals
    ADRENALINECYCLEINC.COM
    Like us on Facebook
    [IMG]http://www.facebook.com/AdrenalineCycle1?ref=hl
    Sep 2010
    Plymouth, MA
    Re: Nesr r6 wisdom
    Ok, so I got the surging to stop during warm idle by manually taking away some fuel in the idle rpm range... specifically from 8 to 5 in the 0 throttle column. Bike is idling perfect, but it is fully warmed up. Now to let it cool back down and see if it will start up ok and idle with no issues. Funny, because I called Dynojet and the guy told me to add fuel to those columns but it didn't work so I just tried taking some away and voila, it worked! I appreciate all the input guys, will update after a cold start.
    LRRS am #121
    Re: Nesr r6 wisdom
    you're still ugly
    Re: Nesr r6 wisdom
    and Jims nuts were on YO TANK.....
    Sep 2010
    Plymouth, MA
    Re: Nesr r6 wisdom
    Jim you've been talking alot lately... reminds me of myself in my pre-novice days. Can't wait to see who wins our first race together...
    LRRS am #121
    Re: Nesr r6 wisdom
    i never claim to be better or faster than anyone.
    but i will say that i'm installing a 7th gear in my motor to cover when i'm WOT in the rain
    Re: Nesr r6 wisdom
    Ogh shit............
    For those who are watching at home Brian C just called Jimmy2shots out in the first LRRS race of the season....
    WHO WILL WIN.......
    PM FOR odds and the LINE......
    LRRS EX #99 Kitt's Avatar
    Lake Champlain, VT
    Re: Nesr r6 wisdom
    you can't use an off the shelf map and take it to the track.
    Go get it fixed. I did mine on a fellow racer's dyno (Hoffman). He's skilled, but i'm sure everyone has the "best dyno guy" that works right next door to the "best tattoo artist".
    Sep 2010
    Plymouth, MA
    Re: Nesr r6 wisdom
    Oh yeah, I'll be doing the custom map for sure, but I just want to make sure everything is good with the new hardware install, and that there aren't any other issues before it goes on the dyno.
    LRRS am #121
    Re: Nesr r6 wisdom
    Wait wait wait... Brian, you thumbed up my suggestion to richen up the idle, after you yourself proved it wanted LESS fuel?! That's just not right.
    Sep 2010
    Plymouth, MA
    Re: Nesr r6 wisdom
    That was right after I got off the phone w/Dynojet! At least it pointed me in the right direction. Still waiting for the bike to cool completely down to see if it idles cold...
    LRRS am #121
    Senior Member TimmyB's Avatar
    Southern AZ
    Re: Nesr r6 wisdom
    taylor does the best cover-up work though..not the most sterile joint, but the price is right.
    Lake Champlain, VT
    Re: Nesr r6 wisdom
    MotoAddiction has a good relationship with some of the yami geeks at dynojet... did you talk to Dusty?
    #331 CBR929RE's Avatar
    Bridgewater, MA
    Re: Nesr r6 wisdom
    the only experience I have with tuners is RJ's/RPM motorsports in Nashua who did my 929 and it came out awesome. and Dyno Solutions who did my 600 for the previous owner and it was good too. might give Rob a try once I get the bike ready for it.
    Sep 2010
    Plymouth, MA
    Re: Nesr r6 wisdom
    Leaning it out worked... started right up this morning and idled perfect cold. It got a little weird from 110 to 130 degrees... rpm dropped a little low, then came back to normal after a few revs and the temperature climbed. So there may need to be a few small adjustments but I'm happy, and I think it's safe to say it's good to go o the dyno where it can get dialed in just right. Thanks for the help and I'll be seeing some of you in April!
    LRRS am #121
  21. #46
    Nesr r6 wisdom
    You're still ugly Brian.
  22. #47
    KB KB's Avatar
    Manchester NH
    Re: Nesr r6 wisdom
    What is this MotoAddiction thing you speak of Chris?
    LRRS/CCS EX #13
    GMD COMPUTRACK
  1. The 20 commandments of motorcycle wisdom
    By VinceF2 in forum General Bike Related
    Last Post: 10-02-03, 03:50 PM
