Results 1 to 22 of 22
rc51 engine work, pinging Degsy
    Feb 2008
    Rhody
    Degs, I tried pm'ing you but your inbox is full.
    Anyway, a question for you, or anyone else with 51 engine experience. I've got two rc51 engines that I'm planning on opening up, it'll be the first time for me, looking to do it as a learning experience and diagnose some suspected problems, any recommendations, suggestions, insight? I'd also be curious to know what kind of performance upgrades I should/could consider once I've gotten inside...
    Thanks,
    Matt
    Hyper
    Wirelessly posted
    I would suggest getting a time machine and going back 2 months to when we had 2 Honda gear driven v motors in pieces in my garage. You could have learned mucho then. Lol.
    Try CP or moriwaki for oversize pistons. Bigger is always the way to get big gains. You could of course mill the heads and port/polish. There are probably lightweight rods on eBay from time to time.
    What kid of problems are you expecting to see inside?
    I'd check the transmission out thoroughly. Including all the shift mechanism stuff on the left side. You could take the quieteners off the cam gears to free up a tiny bit.
    There's a million things you could do but improving fueling with exhaust and air intake changes are easiest and cheapest.
    Feb 2008
    Rhody
    Re: rc51 engine work, pinging Degsy
    Wirelessly posted
    Damnit!!
    The first engine somehow got coolant in it, I'm hoping it's just the water pump impeller seal. But if not I'll have to check the head gasket I think? The other is the engine from the RC51 that you gave me a heads up about, the one you may have done a little gear shaft rod "repair"... I haven't taken the engine cover off yet to check it out, but from your description of it I'm assuming this is the bike, so I'm expecting to have to do a complete disassembly and repair.
    I guess on the performance side I'm wondering about porting and polishing the heads, but not really sure. As far as exhaust and A/F improvements, I've got Sato low mounts a modded airbox and a custom tune so she's pretty well set up there I think.
    Hyper
    Wirelessly posted
    Well, a compression check on the one with coolant in it is a good start.
    I know what you need for the one with the shift shaft issue. It's an inner engine side case (left side).
    I have an engine stand in my garage. I'm pretty busy with projects right now but you're welcome to use the stand and disassemble a motor in my garage. I'm not using the stand or my engine bench for a while.
    Don't RC51's require premium ?
    you could stop the pinging without taking it apart
    Wirelessly posted
    Lol. Randy. That was my initial thought also.
    Feb 2008
    Rhody
    That was pretty good Randy, didn't know where you were going with the first reply.
    And thanks for the offer Degs, but I've got a good work station, I was looking more for some insight into the basics once I get started.
    Hyper
    Wirelessly posted
    Tear off the side covers on the tranny motor and lay a rum trap for me. Ill show you what's what with that motor.
    Degs, you missed the 1st part of his post.
    your inbox is full
    Wirelessly posted
    I don't do PM any more.
    PM sent
    Wirelessly posted
    PM filed
    pm sent
    Feb 2008
    Rhody
    Hey degs, got the engine on my work bench, pulled the left side engine cover, can you tell me exactly what I'm looking for?
    Hyper
    Wirelessly posted
    Haha. Look inside for some JB weld skillfully holding a bolt in the shift actuator system.
    Feb 2008
    Rhody
    Ok, I think we must be talking about different left side covers. I took the stator cover off, that's not what I need to do I guess?
    Hyper
    Talk to Robert about porting and polishing.
    He is a madd machinest!!!!
    Telll em Eugen says HI.
    SW Rhode Island
    http://www.johnsonenginetechnology.com/index.html
    Feb 2008
    Rhody
    Wirelessly posted
    I just had a thought, are you talking about the RIGHT engine cover (crankcase cover)?
    Hyper
    Wirelessly posted
    Left side. The large cover. From memory it's about 10 8MM bolts.
    Feb 2008
    Rhody
    Wirelessly posted
    Yep, that's the left side cover. So, I don't see anything that resembles your description of the work you did, would it be behind the stator? Or part of the torque limiter? Starting clutch?
    Hyper
    Wirelessly posted
    Give me a call
    508-269-7196
  1. For Sale - Other | 1987 SeaRay Weekender 268 - clean througout, great hull, needs engine work
    Last Post: 08-09-21, 07:37 PM
  2. Bike needs engine work, what should I do with it?
    By reks95 in forum General Bike Related
    Last Post: 11-21-15, 12:27 PM
  3. Replies: 4
    Last Post: 01-26-13, 12:34 AM
  4. RC51 vs. Superhawk: engine
    By Qfactor in forum General Bike Related
    Last Post: 02-01-06, 01:49 PM
  5. Degsy does nice work
    By Jaynnus in forum General Bike Related
    Last Post: 02-25-05, 11:48 AM
