Results 1 to 10 of 10
Recommended Rivet tool
    Lifer R1's Avatar
    Somewhere you dont know...
    POP RIVET TOOL NOT A CHAIN RIVET TOOL
    Ok so i have one of the off the shelf pop-rivet tools and its definitely nowhere near as good as i was hoping for.
    I did the rivets this weekend for * *** * ****** ******* and I had 2 misaligned and not tighten down good enough
    I realize this had partly to do with the user, but the problem is for this application for me to even correct the 2 rivets that are off i need remove all of them and re-assemble.
    so heres my question(s)
    is there a better tool on the market that will guaranteed tighten them down to proper levels (no spec really just tight enough to stop from rattling under very very high vibration)?
    Should i just re-use mine as there arent any better out there?
    If anyone has one is there a chance of letting me borrow it for a day at the most?
    Does anyone have a pneumatic pop rivet tool?
    can you adjust the amount of torque?
    ideally i would like to go this road as i am sure they are way more reliable and easier to get that little extra out of....
    Banned Rambunctous's Avatar
    Waterville Valley, NH
    Re: Recommended Rivet tool
    Did I meet you at the track last weekend?
    Dec 2005
    Near The Dragon
    if the rivet rattles then the size chosen for the hole diameter and depth was not the right one (typically). the mandrel may be popping too early allowing the rivet to be loose.. but that would be a crappy quality or improper sized rivet for the application
    Get out while you can
    Find your own path
    Lifer R1's Avatar
    nope. i havent been to the track since last year
    Quote Originally Posted by Cerberus View Post
    alright then.
    apparently you didnt read how i fucked it up.
    all the other rivets are fine its a matter of not putting enough pressure on the rivet when i secured it and after i inspected them all i noticed it was not flush with the material. so i had the bright idea to use a rubber mallet to just push it in a little further and bingo a rivet that rattles.
    Wirelessly posted (BlackBerry9530/4.7.0.122 Profile/MIDP-2.0 Configuration/CLDC-1.1 VendorID/105)
    Using the mallet was the problem.
    As far as rivet tools... I bought a craftsman one for about $20 and it works great.
    It also helps to get good quality rivets too. Aluminum won't hold nearly as hard or long as steel, and stainless is probably the best you can get. The aluminum will also react if you pu them in steel and corrode, helping to loosen them even more.
    Dec 2005
    Near The Dragon
    Quote Originally Posted by R1 View Post
    alright then.
    hmm. well sadly there is no tool which can completely overcome operator error
    and since you know the cause of the problem, i'm not sure what you are looking for. Any pop rivet tool would do the same thing in the same circumstances.
    As far as tightening down to a specific level, the diameter and type of mandrel (the pin that pops) determines how tight the rivet will be when it is done, assuming you hold it flush while pulling it down. you need to use the right rivet for the application. for the rivet, probably stainless is better than aluminum, and the largest head/mandrel size that will fit.
    There are better and worse tools out there for sure.. i have a $55 matco swivel head pop rivet tool that i bough twhen i was in the auto trades. its a great tool, but it still only does what i make it do.
    Find your own path
    Waterbury, VT
    Go with the steel rivets - they hold up over time better. The aluminum ones will loosen with vibration. Drill the hole the right size - the rivet should need to be pushed through, not slip in easy. Use the right length - you should have a good sized bulb on the inside when you're done. If you're holding plastic pieces together try to use the backup washers.
    SSearchVT
    Lifer R1's Avatar
    the rivets used are SS rivets
    it was indeed operator error and yes the malet was a poor decision.
    Ill get some more SS rivets and try it again.
    If i have the same problem then i guess i was just not meant to install rivets into any high vibrations systems
    that or not use the rubber mallet.
    As I'm sure you've already figured out and know. Make sure the rivet head is flush with the material.
    Also, maybe do a short pull on the mandrel, until you feel good resistance. Let go, make sure the head is flush, then do your final pull to secure. That worked for me in recent history.
    Lifer R1's Avatar
    Wirelessly posted (BlackBerry8330/4.5.0.131 Profile/MIDP-2.0 Configuration/CLDC-1.1 VendorID/104 UP.Browser/5.0.3.3)
    The only part that sucks here is that 10 rivets worked perfectly or I should say installed perfectly yet because 2 are suspect the whole system needs to be re done.
  1. Chain Rivet Tool:
    By Trajiks9 in forum General Bike Related
    Last Post: 07-22-10, 08:32 AM
  2. Wanted: Chain Rivet Tool
    By Hammerspur in forum Wanted
    Last Post: 03-15-10, 03:06 PM
  3. Master link rivet tool
    By bluej511 in forum Bike Maintenance
    Last Post: 08-20-09, 09:27 PM
  4. local chain rivet tool
    By Truth in forum Bike Maintenance
    Last Post: 09-06-08, 11:34 AM
  5. rivet chain tool
    By skiierx in forum General Bike Related
    Last Post: 07-11-05, 02:48 PM
