Results 1 to 12 of 12
Replacing ignition key/switch?
    Sep 2007
    Middlebury VT
    Question Replacing ignition key/switch?
    1984 Kawasaki Ninja 900
    I'll be attempting to replace the switch in a few weeks when the new one arrives.
    What is the deal with the fasteners holding the switch in place.
    Do I need a drill now?
    Thanks
    Mar 2004
    woonsocket ri
    Re: Replacing ignition key/switch?
    I dont know about your specific bike, but the ones I've done were screwed in from the bottom so you cannot see them or access them without some dissassembly. You shouldnt have to drill anything out. look closely at things for hidden covers ,screws or obstructions hiding screws.
    Sep 2007
    Middlebury VT
    I'll take another look but they look like a torx with a broken off pin in the center. Switch on the bike is OEM.
    Thanks
    GRRRRRRRRRRRRRR! capt1014's Avatar
    Apr 2006
    Ashburnham, MA
    Eric, I replaced or rather fixed my ignition switch when they key broke off, (cbr 929) if you don't have the torqx driver, like I didn't you can drill off the heads and replace the screws with new torqx or like I did replace them with allen screws.
    http://www.facebook.com/#/profile.ph...&id=1185417660
    Live life now!....it has an expiration date!
    Friendship is like peeing in your pants,
    Everyone can see it,
    But only you can feel the true warmth.
    No Post Count Lurker RGVER's Avatar
    Nov 2006
    Milford, MA
    I either cut a slot with a dremel for a screwdriver (if you're replaceing it)or left twist drill it if the drill doesn't get it then easyout it (if you want to reuse switch)
    Posting Freak
    New Hampshire
    You can buy those safety torx bits just about anywhere.
    Mar 2004
    woonsocket ri
    Quote Originally Posted by Ryno View Post
    Try fastenal. They have them on the counter in most stores. I didnt realize thats what you had. Some people say you can break off the pin, bur I've never tried it.
    Just Registered VinceF2's Avatar
    Feb 2002
    I bought a set of those safety bits at Harbor Frieght for like $10...
    KB KB's Avatar
    Manchester NH
    Take a punch and flatten out the dot in the middle and use the torx you already have in your toolbox. Easist way I have found!!
    LRRS/CCS EX #13
    GMD COMPUTRACK
    High maintenance priss
    Central MA
    Quote Originally Posted by RGVER View Post
    Pretty sure most bikes have red loctite on the ignition switch bolts. IMO would be a bitch to try to remove w/ a slotted driver.
    Just get some security torx bits like a couple others mentioned. Any Sears store will stock them.
    IWOK Prez. bigred875's Avatar
    Manvile, RI
    i had an 86 ninja and just unscrewed the 2 scews holding it on, unplugged the harness and paid a locksmith $27 to cut a new key for me.
    live to ride seth399's Avatar
    Feb 2007
    CA
    Quote Originally Posted by Ericthejet View Post
    Thanks
    ya in that case you can get torx bits that are tamperproof (hole drilled in middle). I had to replace one on an 89 gsxr and it was just 2 bolts underneath, I just used regular button head screws.
    *edit* looks like 39 people already told you that info above...oops haha
    LRRS #399
    MX #505
  1. Toggle Switch instead of key-ignition
    By norco4hun in forum General Bike Related
    Last Post: 07-07-14, 09:38 AM
  2. PITA ignition switch.
    By Ericthejet in forum Bike Maintenance
    Last Post: 03-21-09, 07:45 AM
  3. replacing the cow...
    By Kitt in forum Pit Area
    Last Post: 06-30-07, 11:43 AM
  4. Kickstand Switch for ignition kill
    Last Post: 06-30-04, 09:09 PM
