Results 1 to 12 of 12
Kickstand Switch for ignition kill
    Pepperell, MA
    Is there a way to bypass this safety feature? Is it as easy as unplugging the switch wire?
    When the kickstand is down I cannot run the bike what so ever... Not sure if thats how this model was set up, or if it's a malfunction?
    www.tailofthedragon.com
    the phear hohum's Avatar
    Jul 2002
    Everett, MA
    A kickstand switch is typically just a simple switch, so usually you can just remove it/unplug it.
    Cheers,
    Chris
    Jul 2002
    Everett, MA
    Re: Re: Kickstand Switch for ignition kill
    Originally posted by Mystery Squid
    Not a malfunction... same goes for my bike, it's to prevent you from riding off with the kickstand down.
    Yeah, but some bikes will let you start them in neutral with the kickstand down, but others won't (Ducati ST4 as an example). In other words, the kickstand switch only acts as a kill switch if the bike is in gear, but if its in neutral you can start the bike normally...
    Personally, I start the bike with the kickstand down quite alot, and if I couldn't start it in neutral with kickstand down, I'd be pulling out that switch fast-like.
    Cheers,
    Chris
    Re: Re: Re: Kickstand Switch for ignition kill
    Cheers,
    Chris
    werd... i almost always start the bike when i'm putting on my gear & not on the bike... unless it's already warmed up, then i'm on it & hittin the starter. but if it's cold, i start it up before throwing on my stuff & don't get on it till i'm ready to go
    but i guess this doesn't help Halfie
    "Offspring" wastedincome420's Avatar
    Hickvile USA
    Do ya have a manual w/a wiring diagram Mike?? You should be able to by-pass the kick stand switch w/out much work.....you may haveto just ground ou the wire
    I'm glad my bike doesnt have that....it would drive me up da wall
    Honda (RC26) VFR700
    "hey Randy, do a wheelie!!"
    Pepperell, MA
    I didn't even get a freakin owners manual.. Forget wiring diagram... I am just going to disconnect it.. Fuggit..
    Thanks for the help peeps... Going to get the battery after work and throw it in and hopefully take a test ride around a few quick back roads to see what else is up with the bike... Hopefully it will be ready to rock and roll next week and I can schedule an appt with the state insp for a reconstr title...
    Waterbury, VT
    The switch is either normally open or normally closed. If you unplug the switch and the bike doesn't start at all jumper, the wires together and it should start up regardless of the kickstand position. Good Luck...
    SSearchVT
    Pepperell, MA
    Um yup, I unplugged it and no starty... So what do you mean to jumper the wires, switch the connections over. Theres only two wires.. So try changing the two connections??
    Jul 2002
    Everett, MA
    He means to try holding the two wires for the switch together to complete the circuit. (jumpering them)
    Either the switch acts as cutoff in the open position (in which case if you unplugged it it should run and start with no problems), or the switch acts as a cutoff in the closed position (which seems like its your case, so tape the two wires together to complete the circuit and see if it starts)
    Cheers,
    Chris
    Make sure the switch is properly in place, i know one of the bolts that holds it in place sometime loosens up and falls out on the pre 02 models.
    The R1 should start with the sidestand down as long as the bike is not in gear. If it's in gear and the sidestand is down, it will not start even if you pull the clutch in. Does the neutral light work? It's all directly related and if someone hacked up the harness when they stole the bike, they could very well have cut a wire?
    It's not a good idea to bypass a safety feature like that and there's probably a good chance something like that would be checked when you apply for the reconstruction title and inspection
    Pepperell, MA
    Yeah Mark, there is no Nuetral light while in Nuetral, so your on to something here! Bike starts fine with kick stand up in nuetral or in gear with the clutch in. Will not start either way with stand down... Did you have to pull the clutch in on your 98 to start even in nuetral???
    I'll investigate further!!
    No, i didn't need to pull in the clutch while in neutral to start it. You've either got a bad neutral switch or a wire has been cut, nothing is wrong with the sidestand switch, if the neutral switch was working properly, it would override the sidestand switch.
    I had the R1 service manual but i gave it to Todd to use if and when he ever puts his R1 back together
  1. Toggle Switch instead of key-ignition
    By norco4hun in forum General Bike Related
    Last Post: 07-07-14, 09:38 AM
  2. Kickstand Switch Types
    By CEO in forum General Bike Related
    Last Post: 07-07-11, 07:37 PM
  3. PITA ignition switch.
    By Ericthejet in forum Bike Maintenance
    Last Post: 03-21-09, 07:45 AM
  4. Replacing ignition key/switch?
    Last Post: 01-15-09, 03:50 PM
  5. Kill Switch
    By nhroketboy in forum Pit Area
    Last Post: 04-10-02, 08:02 AM
