I need to use a kickstand switch for a non-motorcycle purpose. I think they are the plunger switches.
I can't remember if they usually work in the direction I need. I pulled the one off my r6 but it was a while ago.
The switch needs to be normally pushed in and the circuit complete, tension required to pull the plunger out which will make the circuit incomplete.
Maybe a brake switch would work too.
Fairly beefy and weather-resistant.
Thoughts on which switch/bike I could use?
Zip-Tie Alley Racing
LRRS/CCS #103
most kickstand switches are "closed" in the 'plunger in' position... I have a few laying around, but the problem is, the plunger is sprung on all the ones I have to be at a natural state of "open".
Front brake and clutch switches work similarly to the above description.
For the function you are looking for, then you really want a Rear brake sensor... Probably any (for free off a race bike) would do. If you're looking to buy new - an aftermarket SuMo switch would be cheaper than an OEM. I had good luck here with my street legal tard bits: http://www.wheelingcyclesupply.com/index.shtml
The type of switch you want is called "normally open"
this is cheap, but probably not weather resistant
http://www.sears.com/shc/s/p_10153_1...=00-12014402-2
LRRS/CCS #103
normally open refers to the fact that in its steady state, the switch is open, when the switch is activated, it closes the circuit. I assumed thats what you were looking for.
A normall closed switch would be one where in its seady state, the circuit is closed, and when you activate it, it opens the circuit.
I wanted to give you the technical term to help your searching
LRRS/CCS #103
LRRS/CCS #103
can you describe what youre doing so I can help better?
all I can think of so far is lame jokes about "when you pull out"
You're looking for a momentary pull switch. The only thing I can find readily on-line is one for marine applications, made by Cole Hersee, see HERE for an example. Not sure of an OEM switch like this, but maybe see if a Yamaha boat dealer or something has what you need.
I don't know how water tight you need it or what mounting options you need, or I may be able to help you more.
This... (Static = On, Pull = Off)
Is not equal to these: (Static = Off, Pull = On)
If it's the first one, then the switch I'm familiar with will work:
http://www.bikebandit.com/2006-suzuk...9755#sch509238
The brake switch I'm thinking of is from a GSXR of many vintages I believe:
Suzuki GSXR (should be able to find a dozen on NESR alone) 600 (2006)
Microphiche: Electrical/WiringHarness
18: SWITCH ASSY,STO
1075769
(495708-001) $20.88
Sorry I confused myself... the first description I initially typed is the one I need.
So it sounds like Kitt's will work. I found a brake switch that was the opposite, I don't know if it is the exception or the rule, but if yours is the way you say then I think that will be good. Thanks kitt!
Thanks anyways Eric but I gave you the wrong description.
ANd xrocket... actually no, I can't, but I appreciate your help. A lame joke is still welcome though.
LRRS/CCS #103
hhahah, okay, glad I could help? sorta?
Car door switch
whatever kind if switch you get, normally open, normally closed, you can use a relay to reverse the switching action
So Kitt, I ordered that switch and it does not function in the manner we discussed.
The one listed is normally open (no juice) and plunger in, and when you pull the plunger out, the circuit closes (juice flows).
We need the opposite.
Any ideas?
LRRS/CCS #103
2018 Harley Road Glide
2000 Ducati 900ss
2003 Harley Softail Deuce
LRRS/CCS #103
Chris.
You need something like this?
They're $8 new from any Parts Unlimited dealer.
Ted I think that one would have the same problem (opposite function than I need). Thanks though
LRRS/CCS #103
