I put stabil in my lawnmower and it has started every spring with no trouble, put it in my generator and I have to clean the carb every time I want to start it. My theory, generator has a steel gas tank which condensates with temp change, lawn mower has plastic tank which doesn't
Put a fuel petcock on the genset and shut it down by running the carb out of gas. You'll never have to clean out the carb again.
Another genset tip: if it's got a flat head (non-OHV) engine, check and adjust the valve lash regularly. Running those old style engines at 3600 RPM makes the valves recede pretty quickly.
