Results 1 to 9 of 9
Squeaky brakes at low speed
    Lifer Punjistick's Avatar
    Norwell, MA
    I've got 13,900 miles on the original OEM suzuki pads. I still have a ways to go before the pads reach the wear indicators. I unbolted the calipers tonight and the pads look a bit shiny. I'm guessing they are a bit glazed from frequent slow, gentle stops.
    I plan on cleaning the calipers and rotors well and gently scuffing up the pads and rotors. What's the best way to scuff up the pads and rotors? Fine grit sand paper?
    Re: Squeaky brakes at low speed
    Ride around for a bit to produce some heat then try building up some speed and doing a few deliberate stops which will usually scrub the brake components.
    Find a safe place like an industrial park.
    Mar 2011
    Sometimes it is possible it is not the pad making the noise and the pad supports/ guides that are squeaking. Take the pads out and clean all the guides and lube them up.
    Clean the pad pins and put a small amount of never seize on them.
    Feb 2009
    Burlington
    My brand new Duc does this. Drives me nuts pulling up in traffic on a Ducati that has squeaks coming from it.
    Banned Rambunctous's Avatar
    Waterville Valley, NH
    Try not using low speed.
    Jack Wagon hefdukes23's Avatar
    Portland, ME
    "When in doubt - gas it. It'll either fix the problem or end the suspense!"
    07 Triumph Daytona 675
    04 Suzuki GSX-R 600
    Norwell, MA
    I'll try all the above. Thanks.
    Lifer Danz19899's Avatar
    Grafton, Ma
    what i've found is a lot of the time its either the guide pins or actually the pad itself.
    i've had to take my pads our and use a little sand paper to smooth off the edges and its fixed it for me a few times
    www.bostonmoto.com
    Ride to live, live to ride
  1. EBC vs. DP Brakes
    By ChicknStripEatr in forum Bike Maintenance
    Last Post: 08-06-10, 01:30 PM
  2. New Brakes
    By Legion1440 in forum Bike Maintenance
    Last Post: 03-22-10, 10:09 AM
  3. KTM brakes
    By MysteriousR1 in forum General Bike Related
    Last Post: 01-23-10, 07:39 PM
  4. Brakes help
    By HBerry in forum Bike Maintenance
    Last Post: 06-23-08, 02:33 PM
  5. New Brakes
    By alwyzbroke in forum Bike Maintenance
    Last Post: 10-30-07, 08:14 PM
