Results 1 to 12 of 12
Starting Problem
    www.reklessracing.net
    Starting Problem
    I've been having a small issue with my bike from time to time. If I don't ride her for several hours she starts up just fine. Once I go to start her back up after a few minutes of being shut off she wont start back up and I have to jump her. Any suggestions on what could be the problem?
    Admin @ www.ReklessRacing.net Check us out
    Sep 2007
    Middlebury VT
    Re: Starting Problem
    Remove your battery, check for fluid levels, possibly charge after topping up.
    I disconnected the battery while it was running to see if it would die down...it didnt shut off but was running very weird
    Sep 2007
    Middlebury VT
    Quote Originally Posted by Ericthejet View Post
    Did you do this? It may just be a battery issue IMO.
    its a sealed battery
    i just dont want to start buying parts to try and eliminate a problem
    Lifer DuncanMoto's Avatar
    How old is your battery?
    Do you use a trickle charger?
    Have you tested it?
    not sure how old the battery is
    no i dont have a trickle charger or gotten it tested
    ill have to do that this week after work
    More times than not, the battery is weak or one of the cells is gone.
    If you don't use trickle chargers (especially during the winter months) then you should expect to have to replace the battery every 2-3 years.
    Charging systems on bikes are different than cars. Taking off the cables while running, does not yield the same results as in a car.
    If you're near Brighton, MA. I have a charger/tester you can borrow.
    how far is brighton from new bedford? or dedham since im working up there
    Probably 8 miles of city driving. 15-30 minutes depending on traffic.
    I'm going to the Larz Anderson today for Tuto Italiano. If you're going let me know and I'll bring the charger with me. Or for $60 I can mail you your very own.
  1. starting problem...
    By JunoAF in forum Bike Maintenance
    Last Post: 07-03-08, 06:37 AM
  2. Starting problem with the '84 Ninja 900
    By Ericthejet in forum Bike Maintenance
    Last Post: 09-27-07, 08:01 AM
