Results 1 to 25 of 26
When a Hawk motor goes _____________
    I don't see anything wrong here
    The big question is whether or not I can re-use the crank or even reuse the cooked rod?
    This was Black Squirrel 441 (AKAMongoos441) engine. He had a number of what I believe to be were seizing moments that led to a total failure down in Jennings FL. One of his crashes he believed was because of a vapor lock. I think it was a seizure. One day he brought it over my place to be worked. Come to find out it needed 2 quarts of oil. This was a warning. In turn we did a total oil change only to find out that the oil was metallic. I told him that I think there is more to this engine than just being down 2 quarts of oil. Before he headed off to FL I told him to constantly monitor the motors performance and be ready at a moments instance to pull the clutch in at any moment.
    Well he listened. The motor had a total seizure and he was able to keep the bike upright by pulling the clutch in.
    Lifer Pittenger5's Avatar
    Austin
    Re: When a Hawk motor goes _____________
    Yikes
    Zip Tie Alley #505
    For a Motor That was Dead, It was fast as stink Really Fast. Ask the 12 SV's I beat un LWss. The first time I rode it. It also Won a race when I had my hand up and the bike in Nuetral when the green flag dropped (wave confusion) From the last row I launched when the first Row was into turn 1. The highlight of my racing to date. If the motor did not fry I would still be racing it
    I hope the is something there you guys can use,
    Cause you guys are the Best
    The pics do make my Hand hurt
    Zip Tie Alley Racing #444
    Signature edit by Tricky mike
    Lifer brewmaster's Avatar
    Apr 2004
    Portsmouth, NH
    Quote Originally Posted by BLACK SQUIRREL 441 View Post
    And your wallet I would assume. Gino you da "hawk" man, glad to see you are so supportive to these cute (and fast) old bikes.
    M900ie
    SS750
    69 gas gusslin' Chevy
    LRRS EX #418
    Lifer obsolete's Avatar
    Norf Sho
    The bulb burns brightest before it burns out.
    Usually cranks and rods can be cleaned up and bigger bearings used. I dunno about bikes, but I've done it in cars with a spun bearing. If it seized the rods should be checked if they're bent. It needs to be sent to a machine shop that specializes in motorcycle engines.
    My education rep. in the VA is friends with a guy in Maine that does crank work for some racing teams. I forget exactly what he told me, but do you me to find out his info?
    -Alex
    Meriden, Ct
    Looks good to me...
    Personally, if it were my race bike, I would buy new rods and have the crank checked and balanced at a reputable engine builder's recommended machine shop. Once all that is done, you can measure and order the appropriate bearings. Honda sells a shitload of different thickness bearings.
    Dec 2003
    Ma
    Running a bike a few quarts down on oil lowers the weight....makes it faster....
    Old and Slow Sheppo's Avatar
    Westford, Ma
    +1 I agree. Rods are cheap enough. Unless the crank is toast you can get it repaired.
    Posted by Jane in BoxChat
    Sep 2006
    Around the corner
    I know a guy!!!!
    The rule is:
    Raymond NH
    This is obviously caused by leaving used oil in the engine for the Winter. You can see how badly the acidic combustion by-products in the oil corroded those rod bearings and crank journals. Imagine how bad it would have been if it wasn't two quarts low! Probably would have dissolved the oil pan.
    Just Registered Doc's Avatar
    Jericho, VT
    Did it go... braaaaapppp.... screeeechh... clang, cracka boom boom...?
    Super Moderator beet's Avatar
    May 2002
    Meriden CT
    Looks like it went zoooooooooot ya spun the bitch. not that bad IMO get the crank polished fit the new bearings bata bing. I've busted rods doing the same.
    www.bostonmoto.com
    Forum Rules
    they always go fastest right before they go boom
    Austin
    Phew, my bikes are safe.
    Zip Tie Alley #505
    Oct 2005
    Wrentham MA
    Yes this can happen...many a motor has been ruined this way....
    BUT...For all those out there that just put their bike away wet :-)...
    If you ran the motor hot for about 20-30 minutes before putting the bike away - there is no issue with leaving the “old” oil in the bike... over 20 minutes at temp the oil is hot enough to outgas all the bad stuff....
    BTW the worst thing to do is start it & warm it up a few times though the winter... just let it
    Graham
    KB KB's Avatar
    Manchester NH
    Nice work Gino. You sure know how to kill a crank!!!
    LRRS/CCS EX #13
    GMD COMPUTRACK
    Credit goes to Daniel for this one. I only know how to find the problem ones
    At least I did not run into this issue:
    Westford, Ma
    OUCH !
    Lifer joeswamp's Avatar
    Sep 2006
    Swampscott, MA
    You can fix that with JB-weld
    Joe
    04 Thruxton (Street)
    01 SV650 (Track)
    Apr 2004
    Portsmouth, NH
    That must have been DAMN scary when it happened!
    M900ie
    SS750
    LRRS EX #418
    hondabond
    pour some 'tussin on it.
  1. Wanted - Parts & Tools | F4i Motor
    By Baggey22 in forum Wanted
    Last Post: 04-24-19, 09:23 AM
  2. For Sale - Motorcycles | Spotted on the Hawk Forum: Hawk GT in Boston
    By Garrett in forum For Sale
    Last Post: 04-29-14, 06:22 PM
  3. East Coast Hawk, West Coast Hawk... :)
    By RadHawk in forum General Bike Related
    Last Post: 04-17-14, 03:17 PM
  4. Ninja 250 motor transplant... what motor to use?
    By DynoTune in forum General Bike Related
    Last Post: 01-06-14, 08:04 AM
  5. My Hawk GT carb tuning. Any Hawk guys advise?
    By Degsy in forum Bike Maintenance
    Last Post: 08-25-11, 05:57 AM
