is it possible to replace a clutch cable on your own? or would this be one for a skilled mechanic? my cables extremely stretched and at this point i cant screw it out anymore at the clutch lever to get a decent amount of play.... any suggestions?
do it yourself it's simple. loosen at lever. take screw out of the arm at your crankcase lift off rotate out cable on both ends. put back on in reverse. Adjust cable, Ride. 1/2 hour if your slow.
ride 1/2 hour if i'm slow? what if i'm fast? more or last time..... slow being speed limit? or what is fast? cuz i tend to cruise back roads and side streets at around 50-60, 100 on highways
notice the punctuation. you need to pause at the period (this thing . )
The 1/2 hour is the time it should take you. and judging by your post your slow![]()
