Not a big deal. Just adjust it.
Could have always been right on the threshold from the factory but never set off the code until now. Normal usage would do it and this is likely the only time you'll need to adjust it. If you did some work to the bike then the TPS could have been bumped...who knows? It's a very sensitive item so it doesn't take much to throw them out of whack.
I did that adjustment on my SV650 (damn near identical to the GSX manual page you posted) with TLRMan and it made a pretty significant difference in the throttle feel. Mine wasn't even that far out of whack either. It's amazing how little you have to move that sensor for it to make a change.
thanks bergs. like i said, i'm planning on correcting it. jsut curious how it would throw off a code while being winterized. i'm getting some oddball responses on WERA, and i'm not really agreeing with what they're saying.
the winter work I did was a new battery & some front braking stuff. so i wasnt near the TPS adjuster at all. just seemed weird to me
They drift over time, hence why they're adjustable. : )
Wirelessly posted (BlackBerry8530/5.0.0.337 Profile/MIDP-2.1 Configuration/CLDC-1.1 VendorID/105)
Wera is junk now. Not even worth using for anything but classifieds. Bunch of i-bigshots and idiots for the most part.
what do you guys think of this? he keeps saying to reconnect the PCIII at the TPS.
Not unless all else has failed, but it wont hurt if you adjust it because it can be reset pretty easy if you get it out of whack. Its unlikely it got moved if you havent taken anything apart. The code indicates an electrical fault somewhere, and if you've messed with anything electrical ever, you know how touchy things can be. I'd say clean the plug and the connection at the tps and try it again.
Like I said earlier you can check the resistance with a multimeter. If you wanted to see if it was reading right you could check it without removing it.
Jim,
Quick question for you. If the sensor is out of wack does the code come up on it's own or do you have to put it in dealer mode to see if it's off? I currently don't have any FI warning lights. Looks like you have to put it in dealer mode to see. I've never checked mine to be honest.
I know how to jump it. I was just curious if the code comes up on it's own or do you have to jump it (dealer mode) to see if it's out of sync. I'm under the asumption it's fine because I dont have the FI warning light on.
