Results 1 to 10 of 10
new tire plug question
    Lifer oreo_n2's Avatar
    Mar 2002
    Amherst, NH
    my rear tire picked up a little slice, right in the middle of the meat.
    its about an inch long and about half the tread depth deep.
    the tire still holds air fine.
    i am not worried about riding it on the street.
    My concern is with the upcoming trackdays...
    when it goes through some heat cycles on the track could something bad develop in this little slice?
    would it be wise to finish the little cut off by making it into a real hole with a reamer and then plug it with a plug kit?
    Walpole
    I know some of the race tires are made so you can slice in your own tread pattern if need be. If the slice isn't any deeper than your original treads then I wouldn't worry about it.
    2018 Harley Road Glide
    2000 Ducati 900ss
    2003 Harley Softail Deuce
    Angry Man Racing Collision pro's Avatar
    Jan 2003
    NC
    I guess it comes down to how bad the cut really is. If you are going to the track you wouldn't want that in the back of your mind. I would change it to be safe, even if you just put a race take off on for that day. If you need one I have one.
    Collision Pros Racing
    Lifer Karaya One's Avatar
    Springfield, Mass
    REPLACE THE TIRE.
    The integrity of the casing has been compromised, and you have no idea if the air chamber has been damaged.
    Spending $100.00 or so dollars on a new tire is short money compared to a "rapid deflation" on the road or especially during a track day and the damage that WILL cause.
    Check out my eBay store!
    Dave - Motorace - Michelin
    NOT laughing with you {~; bemused's Avatar
    Deer Island, OR
    hm-m-m... I musta missed something...
    I thought he said the cut was "half of the tread depth"... which I took to mean it doesn't even go into the body of the tire...
    jeff f
    '97 RF900R
    Springfield, Mass
    A bike tire flexes upon its entire carcass. This is one way it lays down such a large and consistant contact patch.
    By operating that tire with such a large / deep cut, that area is compromised and will flex in a direction that may not agree with the belting and carcass. You risk deforming it through heat and possibly rupturing the air chamber.
    $100.00 or so is short money to replace the tire. Or would you want to roll the dice?
    Dec 2003
    Ma
    I wouldn't think twice about it. I've got two plugs and a can of green slime in my rear pilot sport, and have not had a problem with it putting the pegs to the pavement. I'll most likely be running this at the trackday as well.
    Member Zero's Avatar
    Nov 2002
    Attleboro, MA
    Note to self - "do not pass hessogood on the outside". Thanks for the heads-up.
    Mar 2002
    Amherst, NH
    yes its only about half the depth... and about 3/4" long. i put a lot of spirited miles on recently and no issues on the back roads.
    i noted similar marks in others tires this weekend as well.
    i think i may have been a little over concerned. its actually pretty tiny, but i will probably go buy a plug kit anyways... just in case.
    Brent LRRS #772
    2006 KTM 560 SMR
    Jul 2003
    monmouth ME
    for $5-$8 slime it for a some peice of mind. doent seem like a bad cut to me. i replaced a rear tire on my gix 1000 and with a week it had a small hole that we couldnt find. it was just losing air pressure over a weeks time. so i slimed it. havent had a problem for the life of the tire. just this week it started showing threads. so i went the life of a tire with a hole in it and a half a bottle of slime. and the tire has no chicken strips and i do plenty of wheelies.
  1. Tire nail - plug, patch or replace??
    By Tekime in forum Bike Maintenance
    Last Post: 03-15-16, 09:53 PM
  2. Rear Tire Plug x2 Advice
    By rsw81 in forum Bike Maintenance
    Last Post: 05-04-13, 12:07 AM
  3. tire plug kits
    Last Post: 06-07-12, 02:14 PM
  4. Tire Plug Kit
    Last Post: 08-25-07, 10:13 AM
  5. tire plug kit?
    By bemused in forum Bike Maintenance
    Last Post: 11-27-03, 08:42 AM
