So on the SV, 2001, 1st gen, when sitting at stop lights every now and then theres just a big clunk from the engine. Its somewhat common, but not consistent enough that I can narrow down where its coming from. I think it only happens in neutral, cant really feel it when riding, but that might just be masked by the sheer unadulterated joy I get from riding that bike. I know a clunk from the engine is extremely descriptive, I tried searching online, and it seems to be a common ailment, just wondering if anyone has experience with this, and or how to fix it.
Misfire clunk? Engine ping? Detonation?
Do it with the clutch in while in neutral?
I used to hear the same thing on my 1st gen SV650. I always thought it was just just the "thumpiness" of the twin, but maybe it really is a problem. But mine only happened when it was cold.
2023 KTM 890 Adventure R
Fueling issue? You sync the carbs??
Someone on SVRider just had an issue with his bike backfiring. His throttle bodies were loose against the intake tubes, causing a large vacuum leak.
Here is the thread: http://www.svrider.com/forum/showthread.php?t=156006
Ehh, nothing like that. The best I can describe it is when you kick the bike back into first from neutral. That nice thwack with enough force to make you feel it through the bike. But its never popping into gear or anything, just that kind of noise/feeling.
sounds like your just not used to a clunky gearbox.
I have a similar issue in my 2000 sv.
Not consistent at all. Almost feels like a misfire to me in the front cylinder. I replaced the coil and plug wire. Still does it intermittenly.
Man, these SVs sure do have alot of problems....
Shoulda got a Ducati!
Clean up all your grounds and solder all electrical connections from the battery/grounds/etc.
Vmax did that until I make it easier for it to toss a spark.
-Alex
Any that supply power to the ignition. Including the crimp on the battery leads (both ends), going to the coils, etc.
Helped my Max out tremendously. Now she's smooth as silk even with the cooling fan on in traffic.
Do you mean solder the connections together and bypass connectors or the wire to the connector.
-Alex
Anywhere there is just a crimp connection, flow some solder in there. Wire to connector.
Chain has too much slack.
How many miles you have on that chain?
If loud pipes save lives, imagine what learning to ride would do.
