Results 26 to 50 of 72
Tool help
    IWOK Prez. bigred875's Avatar
    Manvile, RI
    Re: Tool help
    i'm confused....if your chain is so tight it moves the axle when the swingarm articulates that is the problem right there...i thought the axle was moving when you tighten the axle nut...like walking away from teh chain tensioners
    Re: Tool help
    well i adjust the chain slack to spec, then tighten the axle nut. when i tighten it with m breaker bar, my chain slack is gone.
    Manvile, RI
    Re: Tool help
    have you tried keeping it looser then having it tighten to spec when you tighten it?
    how about changing the sequence in which you tighten the bolts?
    also, imo when in doubt more slack is better then too tight.
    Re: Tool help
    Quote Originally Posted by bigred875 View Post
    yes, chain was still too tight
    yes, didnt make a difference
    i've got the axle nut finger tight with the cotter pin in it now. if i got that nut any tighter, i would lose slack on my chain.
    Manvile, RI
    Re: Tool help
    i think you may jsut suck at life lol j/k...something sounds off...are the spacers in correctly? def. have someone take a look at it.....
    Re: Tool help
    I'm pretty sure you're right, but I already knew that a while ago
    Manvile, RI
    Re: Tool help
    seriously though...something doesn't sound right...the only time i've seen an axle "walk" is when there is problem with the spacers....maybe print out the mirco-fiche and compare?
    Foxboro, MA
    Re: Tool help
    oh jim the only thing scarier than me working on a bike, is you working on a bike - be careful pal
    Denno - CCS|LRRS EX#49
    2006 Yamaha R6
    LRRS Rookie of the Year 2008
    Re: Tool help
    denno, wanna come install some no-cuts on my bike
    Foxboro, MA
    Re: Tool help
    all kidding aside - it sounds like you chain tensioners are not aligned properly - get the rear axel in and push the tire from the rear and check to see if your axel nuts are at the same adjustment point on both sides and that the slack on the chain looks good - i know you're huge but i doubt your bending your swingarm
    2006 Yamaha R6
    Re: Tool help
    denno, with the bike on or off the stand? i've heard mixed reviews about rear wheel alignment on the stand
    Manvile, RI
    Re: Tool help
    doesnt matter....if you can't tell with the marks...pick a point on each side and measure it with a ruler
    Foxboro, MA
    Re: Tool help
    i adjust it on the stand
    2006 Yamaha R6
    Manvile, RI
    Re: Tool help
    Quote Originally Posted by Crash Dummy Denno View Post
    +1
    Re: Tool help
    i have both sides exactly on the 4th mark right now. the right side didnt need to get moved, but the left side was about a 1/2 mark off. when i adjusted the left side the slack was perfect. then i tightened the axle bolt with my breaker bar, and noticed the chain slack was gone, but was still on the 4th swingarm mark
    anyways, i have the axle finger tight right now with the cotter pin in there.
    the chain slack is where i want it, and i was planning on riding all day today. is that axle nut considered dangerous since i dont have it torqued to spec?
    Foxboro, MA
    Re: Tool help
    i dunno man - you're doing something wrong- be careful riding
    2006 Yamaha R6
    Old and Slow Sheppo's Avatar
    Westford, Ma
    Re: Tool help
    umm not torqued to spec...no not dangerous. Finger tight even with a cotter pin YES dangerous.
    Posted by Jane in BoxChat
    Re: Tool help
    alright, i'll take a torque wrench from work on my way out of here and torque it down to a avoid a "DBConz Down in Blue Hills Again" thread
    Manvile, RI
    Re: Tool help
    are you working from the manual?
    Re: Tool help
    well i got the torque specs from the manual
  21. #46
    Just Registered Origin's Avatar
    Lynn, Ma.
    Re: Tool help
    It doesnt sound like the problem if how much torque you are putting on..It sounds like reguardless of how tight you put the bolt it will tighten your chain.
    If you put a good amount of slack on the chain and then tighten it, will it go to the correct slack?
    - TJ
  22. #47
    Re: Tool help
    i'll have this taken care of tonight, thanks for your help
  23. #48
    Lifer R1's Avatar
    Somewhere you dont know...
    Re: Tool help
    What about me?
    i dont get a thank you?
    so tonight? still need a cotter pin and help with the cig lighter?
    Manvile, RI
    Re: Tool help
    get the manual, that should have been your first "upgrade"...you can download it on the internet.....look to make sure you have all the spacers in the right place, not missing any washers etc...
  25. #50
    Lifer Jayspeed's Avatar
    Medford, MA.
    Re: Tool help
    Why don't you go ask this question on gixxer.com?
    Jay
    2013 gixxer 750
    2009 Ducati M1100s
    2017 KTM exc-f 350
  1. Tool box help
    Last Post: 07-16-09, 10:18 AM
  2. What a tool !!
    By Sbk12rs in forum General Bike Related
    Last Post: 04-12-05, 09:38 AM
  3. Tool dip...
    Last Post: 03-28-05, 08:59 AM
