all kidding aside - it sounds like you chain tensioners are not aligned properly - get the rear axel in and push the tire from the rear and check to see if your axel nuts are at the same adjustment point on both sides and that the slack on the chain looks good - i know you're huge but i doubt your bending your swingarm
i have both sides exactly on the 4th mark right now. the right side didnt need to get moved, but the left side was about a 1/2 mark off. when i adjusted the left side the slack was perfect. then i tightened the axle bolt with my breaker bar, and noticed the chain slack was gone, but was still on the 4th swingarm mark
anyways, i have the axle finger tight right now with the cotter pin in there.
the chain slack is where i want it, and i was planning on riding all day today. is that axle nut considered dangerous since i dont have it torqued to spec?
It doesnt sound like the problem if how much torque you are putting on..It sounds like reguardless of how tight you put the bolt it will tighten your chain.
If you put a good amount of slack on the chain and then tighten it, will it go to the correct slack?
- TJ
Why don't you go ask this question on gixxer.com?![]()
Jay
2013 gixxer 750
2009 Ducati M1100s
2017 KTM exc-f 350
