Page 3 of 3 FirstFirst 123
Results 51 to 72 of 72
Tool help
  1. #51
    Old and Slow Sheppo's Avatar
    Westford, Ma
    Re: Tool help
    Quote Originally Posted by Jayspeed View Post
    Why don't you go ask this question on gixxer.com?
    they would tell him to chrome the chain and not worry about it.. it's all about the pose...
    Posted by Jane in BoxChat
  2. #52
    Re: Tool help
    i'm all set now, the axle is tight and the chain is perfect. thanks for everyone's help
  3. #53
    Nov 2007
    Re: Tool help
    So did you just have to loosen the chain to account for the tightening when the axle was torqued? Or was it something else?
    Zip-Tie Alley Racing
    LRRS/CCS #103
  4. #54
    Re: Tool help
    needed to put a screwdriver in the sprocket to hold it in place while tighting the axle bolt. got new cotter pins too. thanks again Degs
  5. #55
    Nov 2007
    Re: Tool help
    Oh you mean between the chain and the sprocket to keep it from turning?
    LRRS/CCS #103
  6. #56
    Re: Tool help
    yes sir
  7. #57
    Nov 2007
    Re: Tool help
    yes sir
    Didn't I tell you do to that yesterday on the phone
    If not sorry I forgot. Degsy told me that one back in the day. He's so dreamy.
    LRRS/CCS #103
  8. #58
    Re: Tool help
    Quote Originally Posted by ceo012384 View Post
    he even brought me cotter pins
  9. #59
    Re: Tool help
    Not to keep it from turning. If you put a wrench in between the chain and rear sprocket and keep the chain tight it will hold the wheel against the chain adjusters so that you don't get any slop in there while you tighten the axle.
    IWOK Prez. bigred875's Avatar
    Manvile, RI
    Re: Tool help
    glad to hear you sorted it out
  11. #61
    Re: Tool help
    ha, thanks ryan. i knew degs would fix this with his eyes closed.
  12. #62
    Nov 2007
    Re: Tool help
    Quote Originally Posted by Boston Moto View Post
    Ahh right... I know that since you taught it to me this past winter/spring... but me no talky well what's in my big fat head; turning/sliding/moving/
    LRRS/CCS #103
  13. #63
    Jul 2008
    Waitsfield, Vermont
    Re: Tool help
    i have both sides exactly on the 4th mark right now. the right side didnt need to get moved, but the left side was about a 1/2 mark off. when i adjusted the left side the slack was perfect. then i tightened the axle bolt with my breaker bar, and noticed the chain slack was gone, but was still on the 4th swingarm mark
    anyways, i have the axle finger tight right now with the cotter pin in there.
    the chain slack is where i want it, and i was planning on riding all day today. is that axle nut considered dangerous since i dont have it torqued to spec?
    Is it wise to trust the marks on the adjusters?
    I know mine are off by about a full mark (which I figured out after using a ghetto alignment tool), and I've read about others being similarly off. Then again, maybe it's just a Ninjette issue and chrome keeps them more accurate
    Also, re: using a 3/8 to 1/2 adapter...I'd never go in that direction. If I need to convert down from 3/8 to 1/4 or 1/2 to 3/8, I'd use an adapter (although hopefully not on a torque wrench); I've broken a couple of converters in the past trying to convert upwards, so now I tend to figure that if it's a big honkin' socket (e.g. 36mm), it comes in 1/2" drive for a reason.
    Re: Tool help
    Yes do not ride with one side off a full mark. My chain snapped and wrapped around my leg because of that (and not cleaning the chain). You need to fix it before riding again.
  15. #65
    Jul 2008
    Waitsfield, Vermont
    Re: Tool help
    Perhaps I wasn't clear...my chain/rear wheel alignment is correct. The marks on the adjusters are wrong (i.e. they don't line up even though the rear wheel is aligned), and I was suggesting that I'd be leery of blindly trusting them unless you've verified that they do line up properly.
    Re: Tool help
    So you're rear tire is balanced, but the left and right swingarm marks are different? That mrans your rear tire isn't on straight
  17. #67
    Jul 2008
    Waitsfield, Vermont
    Re: Tool help
    The distance from the front swingarm bolt center to the rear axle bolt center is the same on both sides of the bike, therefore I think the wheel is on straight. However, the adjusters are on different marks on either side. My assumption is that the marks are not an accurate indication of wheel alignment, at least on my bike; this matches what the ninja250.org FAQ says:
    Quote Originally Posted by ninja250.org FAQ
    The hash marks (on all bikes) are Notoriously off. Some may be 2 or more marks off.
    Re: Tool help
    Bring your bike to degsy's and have him use his alignmebt tool to make sure it's exact
  19. #69
    Nov 2007
    Re: Tool help
    Yes do not ride with one side off a full mark. You need to fix it before riding again.
    Christ! You're such a moron sometimes, Jim
    LRRS/CCS #103
  20. #70
    Re: Tool help
    I heard a rumor that Boston Moto may be selling those chain alignment tools soon!!
    Just a rumor.
    Re: Tool help
    because of sweet typing skills on my blackberry while drinking
  22. #72
    Lifer DuncanMoto's Avatar
    Re: Tool help
    I never trust the marks on the swing arm.
    Actually we already sell a very cool German made "laser" alignment tool. It is the balls. I'll throw some photos up later, but here's the manufacturer's link. I have one of these for a loaner tool and we do stock these for $90.
    PROFI PRODUCTS ...not only for professionals ! - Profi Laser CAT
  1. Tool box help
    Last Post: 07-16-09, 10:18 AM
  2. What a tool !!
    By Sbk12rs in forum General Bike Related
    Last Post: 04-12-05, 09:38 AM
  3. Tool dip...
    Last Post: 03-28-05, 08:59 AM
