Results 1 to 10 of 10
tune-up?
    May 2003
    Lakes Region, NH
    tune-up?
    So I am rapidly approaching 8000 mi and other than regular oil changes I haven't done much in the line of "in-depth" maintenence. I figured 8g was a good time to ask if there is anything that I should look into.?. I keep the chain up and stuff but haven't got into fork seals or anything that isn't done on a fairly reg basis. [the fork seals look fine btw ].
    So...is there anything that I should look into on the Rex?
    Bras cause cancer.
    guy on the vintage Yamaha Rice-rocket1's Avatar
    May 2002
    New Bedford, MA
    tune-up?
    What's the valve adjustment interval on it? Should be in the manual....
    My ride's
    95 FZR 1000
    19xx DOUBLE "D"
    May 2003
    Lakes Region, NH
    tune-up?
    i do not know. I will check in the manual later on and figure that out. I am at work so i can't check it now.
    You know - that's a good idea...check the manual...never thought of that....
    Bras cause cancer.
    tune-up?
    yeah bro... i have a whole chart in my owners manual that has a whole boatload of stuff that needs to be checked & the suggested intervals for each
    the phear hohum's Avatar
    Jul 2002
    Everett, MA
    tune-up?
    Yeah, check the manual man. Or you should also be able to find a maintenance chart somewhere online... Heck, I can find one for my bike online and there were less than 1000 of em in my year shipped to the states
    Alot of bikes will spec valve clearance check at 8K miles, typically a fairly expensive dealer service that you can easily do yourself if you can follow directions EXACTLY, and can work a wrench.
    Cheers,
    Chris
    100 X slower than Gerard scootertrash's Avatar
    Alton Bay, NH
    tune-up?
    Air filter. I have the type you have to clean and re-oil. Not sure if you have the same or not. It's pretty easy to do.
    For a late model bike with 8K miles, the need to do spark plugs, valve adjustment, and carb sync is debatable. If you had a race bike you were trying to get every last bit of HP out of, I would do it. For your bike...if it's running well...you need to weigh the cost/benefit/risk of doing or not doing it. If it runs well, doing plugs and a carb sync at this point will not get you much. Doing a valve adjustment won't get you much performance unless it's way out, which is possible but not likely. If it's one of those rare cases where it's way out at 8K miles, you could potentially do some damage if you neglect it too long.
    I recently did my valve adjustment and carb sync for the first time at 14K miles. They were both pretty good as-is and needed little adjustment. If you've never turned a wrench before, don't try it yourself. If you have some basic skills, you can do it by following a good shop manual.
    Just my (non-expert) opinion.
    Jul 2002
    Everett, MA
    tune-up?
    umm, absolute ditto. Its unlikely (but possible) that your valves are out of tolerance at that mileage, and synching carbs is probably not necessary at that mileage either, but if you want your bike to run its absolute best, its good to do.
    Although IMO, its always worth learning how to do all of the basic service elements yourself, including valves, carb sync, plugs, fluid flush fill(oil, radiator, brake), etc, etc.
    If you plan on keeping the bike for any great number of miles, its always beneficial to know as much as you possibly can about how to maintain it and do the regularly scheduled maintenance. Will save you a bundle in the end, just my opinion though...
    May 2003
    Lakes Region, NH
    tune-up?
    thanks for the info guys. As it were i received a PM shortly after posting this calling me a jackass from a certain member here (hehe - I said member) offering to do a complete overhaul with me to show me how to do it all myself. What a nice guy huh?
    Chris - stop braggin about that bike damn-it.....blah blah blah my bikes better blah blah blah I am special blah blah blah only 1000 shipped blah blah blah
    {i would be braggin too if I had one}
    I have a K&N in her so I need to clean and re-oil.
    Bras cause cancer.
    Jul 2002
    Everett, MA
    tune-up?
    Bragging? Heh, hardly. With this bike its more like playing mad scientist to find which jap crack parts will fit cos I'll be damned if I am buying Triumph parts... @$9 a valve shim, its not quite BMW assrape prices ($15 a shim), but still... Hmmm, should I buy R6 clipons for $28 on ebay, or should I buy the Jack Lilley clipons for $fuckmymommatheycostthatmuch! 1000 in the US == exclusivity, but exclusivity == god damn i can't find any parts, and zero fucking aftermarket support. Grumble, grumble...
    Good luck with the tune up, if its the 'member' I think it is, I am sure you'll learn alot and get everything done right Take notes man!
    Cheers,
    Chris
    May 2003
    Lakes Region, NH
    tune-up?
    Cheers,
    Chris
    #1 =
    #2 = hehe - you said member too...
    #3 it probably is....a true 'member' at that
    Bras cause cancer.
  1. Need a Tune - QUICK - Who Should I See??
    By kb1 in forum Bike Maintenance
    Last Post: 08-24-10, 07:10 AM
  2. Oxx came over for a tune.....
    By TLRMan in forum Bike Maintenance
    Last Post: 06-11-07, 07:05 PM
