Results 1 to 20 of 20
Another voltage question... camera hard wiring
    I have an on-board bullet cam set-up from www.cedigital.com
    It comes with a battery pack that takes 8 x AA batteries.
    Do you think wiring it to the tail lights, which show a max of 14 volts is too much? Should I toss a 2ohm resistor in there?
    Dec 2005
    Near The Dragon
    Re: Another voltage question...
    would probably work just fine
    just be sure to clean the lint trap on the flux capacitor.
    Get out while you can
    Find your own path
    Winchester, MA
    AA batteries have a nominal voltage of 1.5 volts, so 8 in series would be 12V. 14 shouldn't be a problem.
    Worrrrd.
    BTW, BEFORE I did that rec/reg wiring mod, when I was only seeing a little over 13 volts, I wired it straight to the battery based on a suggestion by someone else that owned the same system.... it worked fine & dandy when the bike was off, but when it was running there was WAY too much interference.... so I'm looking for a cleaner current that won't overload the camera.
    Winchester, MA
    I would recommend an inline fuse hower, if the camera doesn't have one already.
    Dec 2005
    Near The Dragon
    a small capacitor across the power wires would help clean up the 'dirty' power too, no?
    Find your own path
    I've actually got an extra pig-tail for a battery tender that I was gonna put to use since it has an inline fuse holder... what size do you think I should throw in there?
    Winchester, MA
    Quote Originally Posted by Cerberus View Post
    Depends on what you mean. A capacitor in series with the positive lead will AC-couple the line, blocking DC voltage. A capacitor from the positive lead to ground provides a low impedance path to ground for AC while blocking DC, which is used to filter residual AC ripple on a DC line.
    Dec 2005
    Near The Dragon
    Re: Another voltage question... camera hard wiring
    right. "across the power wires" was meant to imply parallel to load, not in series
    residual AC ripple on a DC line = noise..
    Find your own path
    Lifer daviid's Avatar
    Oct 2004
    Plantsville, CT
    -Benjamin Franklin
    Posting Freak boloson's Avatar
    Oct 2007
    hey pete u gonna have this ready in time for NJ?
    I'll have it with me & play around with wiring & mounting when I have free time. If I can get it working well & we have some dry track time I'll record some of the action.
    Gabba Gabba Hey Stiggy's Avatar
    Jan 2009
    I would think that if the camera has an external power jack there will already be a cap. on the PCB.
    06 RC46
    Dec 2005
    Near The Dragon
    Quote Originally Posted by Stiggy View Post
    possibly, but it is meant to be powered by a battery pack so there would be no reason to design in the ability to clean up a dirty power source.
    Find your own path
    plugged it in to the tail lights.... still had some interference when the bike was running.
    And now the fuckin recording unit, which has its own power supply, just shit the fucking bed
    I've plugged it into a usb port, the charging light turns on but it won't do a fucking thing. Before I could at least turn it on and it would connect to my PC like an external drive... now? not a god damned thing.
    So fucking pissed.
    Oct 2007
    hope u didnt fry it. try removing the dvr battery to reset it. hope thats the only thing wrong with it
    i don't see how it could have fried, it doesn't draw off the camera power source as far as I know.
    Besides, it died while I was replaying the last vid after I disconnected it & was walking away from the bike.
    Lifer akira700's Avatar
    Apr 2005
    in the city
    Pete, what's wrong with just going with the AAs?
    Seems like you are making this more complicated than
    its worth in terms of troubles you can introduce.
    All I know is that messing with electrical stuff by adding
    on extra 3rd party stuff just begs problems down the road.
    2008 Honda CBR 600RR
    Lifer union's Avatar
    Blackstone, MA
    Quote Originally Posted by akira700 View Post
    The batteries are heavy and can fall out enough to cut power or worse head out to the track itself.
    I hooked my camera up to the head lights. Has been working perfectly. Definitely go with an inline fuse. If I remember Ill look at mine and see what one they sent with the package.
    James
    pistol pete, shoot a PM to R1. he's an electronics wiz, and will have a very long, techy, boring, ceo-type response for you. he's my go-to guy whenever i need to get confused on electrical stuff.
  1. Safety wiring question
    By MaRce1o in forum Pit Area
    Last Post: 04-03-17, 05:33 PM
  2. stupid wiring question
    By smf in forum Pit Area
    Last Post: 04-22-07, 08:43 AM
  3. new taillight wiring question
    By hyooz2004 in forum General Bike Related
    Last Post: 02-01-07, 11:11 PM
