Results 1 to 18 of 18
Yamaha Serow Clutch Change, now it wont shift gears.
    TWINS! xrocket21's Avatar
    Central Maine
    So, the clutch in my 1994 Yamaha Serow XT225 was toast, so I bought new clutch plates.
    I replaced them, and adjusted the clutch, now it seems too "tight"
    If I hold in the clutch and shift from N to 1, I can feel it drag. The big problem is that if you come to a stop in 1st with the clutch in, you cant get it into N, you have to be moving to get it into N, or the engine off. Its like the clutch is too "tight".
    I checked movement wit the cover off, and the clutch is disengaging completely, and I put the plates back together the same way they came off.
    My atk actually does the same when its cold, when you shift to 1st from N, you can feel it drag with the clutch in. With the ATK it goes away when its warm.
    It was an issue on the atk (though the atk doesnt shift had), and now that I "solved" the toast clutch on the XT, I now have a similar problem to the atk of the clutch feeling like it doesnt completely release
    LRRS EX #99 Kitt's Avatar
    Lake Champlain, VT
    Re: Yamaha Serow Clutch Change, now it wont shift gears.
    sounds like you did it wrong!
    jk.. what kind of shape was the basket in?
    Sounds like the cable adjustment is too tight.
    There should be at least 5mm of play between the lever perch and the lever prior to the cable physically being pulled.
    Central Maine
    it all looked to be in really good shape
    Central Maine
    Both bikes are pretty tight, Ill try that.
    So basically the lever is pulling the clutch out too far?
    On the ATK it's dragging when cold because of cold oil making the plates sticky. I've been told to work the clutch lever with the bike in neutral while warming it up to help alieviate that.
    If your clutch adjustment doesn't have any free play in it, you're essentially constantly slipping the clutch ever so slightly. You'll dump a ton of extra heat and wear into the system and depending on the design you may do things like shorten your clutch push rod or eat the mechanism that works the rod (Early YZ for example). That excess heat swells things causing drag.
    Central Maine
    Oh no, it isnt snug to the point of not letting the clutch close all the way. I adjust it till the clutch is fully clamped, then tighten the lever just a little less than sung, so there is SOME play in it, but very little, so the lever isnt floppy. Clutch is definitely fully engaging on both.
    Lake Champlain, VT
    did you soak the new parts?
    Central Maine
    ummmm, youre supposed to soak the new parts?
    Lifer DuncanMoto's Avatar
    :OOPS:
    Central Maine
    Quote Originally Posted by DuncanMoto View Post
    :OOPS:
    lololololol
    well, its soaking now The thing has like 25 hp, how much iof a difference cant it make?
    or is that why Im having shifting issues now...?
    Central Maine
    bump it back up
    I soaked them and re-installed them and its still tight as hell
    Should I just buy new clutch plates again?
    It was like $35
    it shifts soooooooo hard.
    edit: ugh I love how I have had this problem for like 2 years and still haven't fixed it
    Central Maine
    http://www.yamahapartshouse.com/oemp...c78c22b/clutch
    this replacement shows two types of friction plate, Im pretty positive I only had one type. Any thoughts?
    Looks like that special friction is sized to accept a spring (Part #19) so I'd say... yeah, if you don't have that assembly, get it.
    Central Maine
    I wonder if the onew I bought wasn't supposed to use the spring? I don't know, either way I ordered now plates and a new spring for $80.
    How long should I soak them for?
    Central Maine
    Update: Friggen thing works awesome now! Shifts like butter and easily clicks into neutral!
    KB KB's Avatar
    Manchester NH
    So uhhh what was the issue?
    LRRS/CCS EX #13
    GMD COMPUTRACK
    Central Maine
    I didn't have the spring matched with the right clutch plate.
    When I bought the first clutch kit, it came all together and I just didn't realize that one plate was a different size.
    When I ordered the second clutch kit, it was individual oem parts, the fact that one plate had a different part number slapped me in the face that one plate was actually different.
    Is it common that one plate is different to match the internal spring?
  1. For Sale - Parts & Tools | FS/FT:Yamaha Rekluse Clutch
    By Kitt in forum For Sale
    Last Post: 10-06-14, 01:19 PM
  2. For Sale - Parts & Tools | 06-07 Yamaha R6 Bazazz QS4 GP Shift Pattern
    By Jason P. in forum For Sale
    Last Post: 07-25-14, 01:53 PM
  3. No clutch lever? No shift lever? No footpeg? No problem.
    Last Post: 08-29-11, 01:25 PM
  4. FS: 2006 Yamaha FZ1 Shift Red, 8.5k miles
    By keeena in forum For Sale
    Last Post: 09-02-09, 10:42 AM
  5. Clutch wont disengage
    By Wishbone in forum Bike Maintenance
    Last Post: 05-05-09, 04:10 PM
