Results 1 to 16 of 16
WANTED: 06/07 GSX-R parts
    Exclamation WANTED: 06/07 GSX-R parts
    need ASAP.
    06/07 GSX-R 600/750 lower triple. must guarantee to be straight. must have damper mounting brackets - thanks VTECLOL
    06/07 600/750 rearset relocation plates. need the OEM ones to bolt up my Woodcrafts rearsets. - Thanks Pigman
    06/07 600/700 rear master cylinder - thanks degs
    Lifer R1's Avatar
    Somewhere you dont know...
    Re: WANTED: 06/07 GSX-R parts
    I got one, but the tab for the stop is sheered off almost completely
    so?
    LRRS EX #99 Kitt's Avatar
    Lake Champlain, VT
    I may have some adjustment plates
    let me know
    and now adding a rear master to the list
    Lifer R1's Avatar
    so yes/no on the lower with broken tab?
    Quote Originally Posted by R1 View Post
    it needs to be able to mount an Ohlins damper
    Lifer R1's Avatar
    ill take some pics for ya tomorrow...
    got a master. updated post #1
    Lake Champlain, VT
    you should just drill and tap yours and add a small tab/bracket. lower triples are $$
    Kitt, the OEM mounting tabs for the linear damper were ground off. so that's not really an option for mounting my Ohlins
    Lake Champlain, VT
    Quote Originally Posted by DBKromz View Post
    off the frame or off the triple? or both??
    I assumed since a triple would fix ya, it was just off the triple. You can just use a small piece of 1/8"-1/4" aluminum... drill 2 through holes, drill and tap 2 holes with same spacing on your lower triple (where the old one used to be).
    Drill and tp a 3rd hole on this piece of aluminum, screw the bracket to the triple, screw the slider of the damper to the bracket.
    no?
    just sayin... cheaper route that will work just as well. If you dont want to tap, you can go with 1/8" steel plate, and just usee machine screwes with locknuts for all 3 mounting points.
    the lower triple mounting tab (left side) is ground off. if i was in a pinch up at Loudon, i'd maybe try the drill & tap fix. but where I have the bike in a garage and not needed to be fixed for a practice/race the next day, i'd rather go the OEM route.
    Lifer obsolete's Avatar
    Norf Sho
    You could also try having the tricky one weld on a tab if nothing else comes up.
    -Alex
    that exact question was asked last night, and i've been told it's best to just get a straight OEM triple with the tabs already mounted.
    picked up a lower triple last night. I think Pigman is sending me the rearset brackets too, so I should be all set.
  1. Wanted - Motorcycles | CBR900RR parts wanted
    By DJA1962 in forum Wanted
    Last Post: 03-09-15, 09:54 AM
  2. WANTED 900 SS PARTS
    By vfr99999 in forum Wanted
    Last Post: 05-08-11, 06:57 PM
  3. Wanted: OEM 2006 R6 Parts
    By deeto in forum Wanted
    Last Post: 03-26-10, 12:53 PM
  4. Wanted/ FS: Parts for 04-05 GSX-R 750
    By hammadown in forum For Sale
    Last Post: 02-22-08, 03:24 PM
  5. Wanted: Honda CBR 600 F4 and F4i parts
    By junior-coyote in forum For Sale
    Last Post: 01-14-08, 02:25 PM
