Results 1 to 7 of 7
kickstands
    I'm looking for a pair of stock kickstands for 1st gen SV.
    Lifer jasnmar's Avatar
    Mar 2012
    Chichester, NH
    Re: kickstands
    One for either side?
    Re: kickstands
    i have 2 1st gen SVs asshole :
    Feb 2007
    Re: kickstands
    What makes them a 'pair'?.
    Mar 2012
    Chichester, NH
    Re: kickstands
    From what I can tell nothing. Pair actually doesn't matter. Sell him one, then the other.
    Re: kickstands
    Oxx, try an 01-04 GSX-R1000 kickstand. If your SV has an aftermarket shock, chances are, the stock kickstand makes the bike lean over quite a bit.
    You will have to file the fork in the kickstand, since the SV's bracket is thicker than the fork. You will also have to drill out the SV bracket hole a little to fit the wider bolt from the GSX-R.
    Re: kickstands
    Quote Originally Posted by smokinjoe View Post
    i need 2...thus a "pair". was that not clear?
    thanks, they do both have aftermarket shocks. i really just wanted them for winter storage and maybe for trackdays. im not sure i understand what you mean by "fork". i dont have the brackets either so i guess i need a PAIR (thats 2 for those keeping score) of those too.
    i have 2 kickstands and brackets but they are bent, but i cant tell if the brackets are bent or if the kickstands are bent so i was just looking for 2 that arent bent.
