Results 1 to 14 of 14
WTB: parts for 1997 CBR600F3
    Just Registered drop's Avatar
    Bradford, MA
    picked up a 1997 cbr600f3 last sunday for my roommate. 10 minutes later it was torn down and pete, tj & i made a list of parts it needs so far.
    before i order the parts, i wanted to see if anyone had any for sale in their "random box of parts" collection. i don't really know honda's line very well, but i'm sure some of these parts fit older/newer years and models as well.
    the immediate list:
    - chain & sprockets 06406-MAL-G01 (aftermarket parts are fine)
    - fuel pump 16710-MAL-601 (it's a carb bike, but has an external fuel pump)
    - bar end 53105-MN4-010
    - throttle grip 53140-ML7-000
    - throttle cable A 17910-MV9-000
    - right handlebar 53100-MV9-000 (probably can salvage the current one, but throwing it out there)
    also looking for right side and tail plastics (black with red & white streak version) if someone has them laying around.
    - Jamie
    2009 K 1300 S
    Savannah, GA
    Re: WTB: parts for 1997 CBR600F3
    i have a fuel pump from my 01 zx6r.... it's carb'd... basically the same thing. just give it 12 volts. let me know
    bergs might have some parts off his F4i, which might be interchangeable.
    Bradford, MA
    Quote Originally Posted by The Magician View Post
    thanks for the offer - i'm going to stick with honda parts for this bike. it's destined for a new rider and i want it to be easy and clear to work on, so trying to avoid any harness/connector/plumbing mods.
    - Jamie
    2009 K 1300 S
    Savannah, GA
    I wouldnt be surprised if the pumps were nearly identical and even had the same wiring... they probably came from the same supplier lol.
    I can take a picture later.. if it looks like yours and something you want to try, let me know.
    Bradford, MA
    if it's not too much trouble: pic of the pump & closeup of the connector/pins would be great.
    - Jamie
    2009 K 1300 S
    Jamie, ask how much If the answer is "free" I'll at least try to make it work
    Savannah, GA
    you can look at the fuel pump on your zzr lol!
    http://cgi.ebay.com/ebaymotors/ws/eB...m=140391590615
    theres a pic of one /... need to dig mine out
    Bradford, MA
    haha good call, didn't even think of that. i'll take a look tonight, no need to send pics.
    - Jamie
    2009 K 1300 S
    Savannah, GA
    Quote Originally Posted by drop View Post
    lol ok. you can even pull yours off and see if it works and if the fuel pump is even your problem to begin with.
    I had an issue where i couldnt get a pump to work... couldnt figure it out.. replaced the relay and that didnt fix it either. i ended up hard wiring the fuel pump to the battery with a switch in it... worked perfectly since the pump is internally regulated. just had to remember to turn it off when i stopped the bike.
    give the f3 pump 12v and see if it fires.
    The fuel pump was pissin fuel... it definitely needs replacing.
    Savannah, GA
    like leaking through the seams? cracked?
    Bradford, MA
    it's leaking fuel from the seam where the two halves of the pump's outer case meet.
    - Jamie
    2009 K 1300 S
    Savannah, GA
    Ahh gotcha. Fair enough. One thing zip ties and duct tape cant fix.
  1. NEED: '97 CBR600F3 Front Fender
    By njsrikar in forum Wanted
    Last Post: 04-06-11, 05:33 PM
  2. 98 CBR600F3 plastics
    By sdog30 in forum For Sale
    Last Post: 07-26-10, 12:49 PM
  3. NEW '97-'98 Honda CBR600F3 Dynojet Jet Kit
    By bump909 in forum For Sale
    Last Post: 10-22-09, 12:29 PM
  4. Air/fuel rate for CBR600F3?
    By sdog30 in forum Bike Maintenance
    Last Post: 09-06-09, 11:19 AM
  5. FS: 1997 CBR600F3
    By The Snowman in forum For Sale
    Last Post: 09-05-09, 07:20 PM
