Results 1 to 12 of 12
WTB: Keyless Start for 06-14 R6?
    Senior Member kumpy's Avatar
    May 2012
    Norton MA
    Does anyone know where I can get one of those switches that replaces the entire ignition and key for 06-14 R6?
    Lifer Pittenger5's Avatar
    Austin
    Re: WTB: Keyless Start for 06-14 R6?
    I built mine for ~20 bucks at home depot.
    Zip Tie Alley #505
    May 2012
    Norton MA
    How? With what parts? Instructions please!
    Austin
    1 of thoses (with the right size to fill the space where the ignition was): http://www.homedepot.com/p/DURA-1-in...2?N=5yc1vZbuf5
    2 of these for the top and bottom, with holes drilled for wires/swich (once again, appropriate size): http://www.homedepot.com/p/DURA-1-2-...-005/100343207
    I got fancy and threw a rubber grommet in on the bottom so the wires wouldnt rub against sharp edges.
    Switch like this: http://www.amazon.com/Rocker-Toggle-...=toggle+switch
    Some silicon and spray paint. And Bob's my uncle
    I even went back and re-did this cause I didnt like the way the silicon looked, so I was more careful the second time around and it looks a lot nicer.
    WTB: Keyless Start for 06-14 R6?-keylessignition-jpg
    Zip Tie Alley #505
    Austin
    Note: for the switch end, I dremeld'd off the "lip" of that plug, and glued the top of it flush, and drilled a hole just big enough for the switch to sit in.
    Zip Tie Alley #505
    Austin
    Also, fun fact: mine's a honda, but should be the same general principle
    Zip Tie Alley #505
    Meriden, Ct
    I'm going to get started on this.
    May 2012
    Norton MA
    I'm assuming its a easy wiring job, you just remove the entire ignition assembly, then cut the wires, then solder the wires to the switch and have it mounted to those PVC things and done?
    Austin
    Quote Originally Posted by kumpy View Post
    I didnt even solder. Probably not a bad idea if you want to get fancy. I just used those compression fitting type things (dont know what they're called), and then put some silicon around it for waterproofing and to prevent them from falling off. But yeah, I hate wiring and it was beyond simple.
    Zip Tie Alley #505
    Check to make sure you don't need some resistors in there like the gsxr's need.....FYI
    Kumpy, S&C sells switches too. got mine for like $40 a month ago
    Junior Member khanlon's Avatar
    Feb 2009
    Norfolk, MA
    You should use a waterproof switch. Otherwise if the switch gets wet the water will jump the connections in the switch and drain your battery.
  1. Wanted - Motorcycles | WTB: first gen sv650 keyless gas cap
    By Johnpewpew in forum Wanted
    Last Post: 03-06-19, 02:30 PM
  2. Keyless Gas Cap
    By JettaJayGLS in forum General Bike Related
    Last Post: 08-18-15, 09:33 AM
  3. Went to Keyless Ignition
    By turbo in forum General Bike Related
    Last Post: 04-01-13, 03:32 PM
  4. Keyless gas cap project
    By jcbell1007 in forum Pit Area
    Last Post: 03-28-13, 06:16 AM
  5. wtb 1/4 turn keyless gas cap
    By catch2otwo in forum For Sale
    Last Post: 12-04-09, 10:05 PM
