Now Available for the 2013-14 Kawasaki Ninja 300!
Rearsets:
Woodcraft's rearsets are machined from tough 6061-T6 billet aluminum, which offers more than twice the durability of OEM rearset brackets. Ninja 300 rearsets feature adjustable footpegs, giving you a new foot position up 1" and back 2" from stock, with 1/4" adjustability for your ideal foot position. The kit can be used in either standard or GP shift, and can be purchased as a base kit (reusing your OEM pedals), or as a full kit, with both pedals. Your OEM pedals can be used for spares on both sides. $359.99 For the full kit with both pedals (base kit also available).
Clipons:
Woodcraft re-designed our 2.5" Riser clipons for the 08+ Ninja 250 and Ninja 300 with an all-new reverse off-set riser plate. Like it's predecessor, this kit gets the bars as low as possible without interference with the stock parts. The new riser plate now allows the bars to be angled more rearward than our old style, allowing for a tighter tuck on the straights. $179.99 Includes your choice of Black or Silver bars.
Frame Sliders:
These Frame Sliders are a special, under-bodywork style that Woodcraft has been successfully using for years on the narrow engine Ducati's. These sliders protect the critical parts of the bike and the under body design helps prevent the longer slider bases these bikes require from being bent. Big additional benefits come from a slider puck sitting against the backside of the bodywork as your fairings gain major support that helps prevent breakage in a crash. This also means there are no "levers" sticking out of the bike to bend frame bolts or flip the bike. $84.99 For full set, sold with pucks included.
