Results 1 to 9 of 9
GSX-R OEM steering dampers
    for those guys who have soaked their OEM dampers in a thicker oil, what have you used?
    I dont have my Ohlins on there right now & the stocker is pretty light.
    EX 105 : CCS Atlantic, Mid Atlantic, South East, Florida, and WERA
    Sponsors: Motul, Michelin/STS, K&N, Woodcraft
    Re: GSX-R OEM steering dampers
    15w to 20w fork oil........
    Also completly imerse the entire damper in the oil, while submerged in oil I ran the damper through its stroke multiple times. Each stroke it would suck in some oil and spit out some air. or set up a tube and funnel and work the Air out of it.....
    See..........> http://forums.13x.com/showthread.php...ht=dampers+oil
    makes me sound SMAT.........LOLOLOL
    thanks piggy. will dealerships have fork oil, or did you buy some from Kates?
    Either one but the stealership will have what you need and get a fresh bottle as its as break fluid and fork oil is Hydroscopic (sp)
    Lifer 03Worc9R's Avatar
    Worcester, MA
    I have mine with 15w. it is more than enough.
    I would think 20w would be way to tough.
    You can have the rest of my quart of 15w fork oil if you want. Was only used for the damper.
    Yea....i would start with 15w and go from there
    thanks guys. i'll go with 15w
    #331 CBR929RE's Avatar
    Bridgewater, MA
    I have nothing to add to this thread except its hygroscopic. I don't know who came up with that cause hydro just sounds like it would be right.
    so i drained out the very little "oil" yesterday. it looked like dark water. i submerged the drain plug in a container filled with the 15w fork oil & moved the damper up and down the piston. took maybe 15 minutes to remove the damper, drain the oil, fill with new oil, and reinstall the damper.
    thanks everyone for the tips.
  1. GPR Steering Dampers? Interchangeable?
    By norco4hun in forum General Bike Related
    Last Post: 01-04-14, 09:26 AM
  2. Steering Dampers
    By Rosco61 in forum General Bike Related
    Last Post: 02-10-13, 01:33 PM
  3. Shindy steering dampers
    Last Post: 06-15-08, 09:44 PM
  4. Steering Dampers
    By wortown03 in forum General Bike Related
    Last Post: 11-26-07, 10:32 AM
  5. Steering dampers?
    By gixxer6 in forum Dirty Bastards
    Last Post: 10-06-04, 07:04 PM
