Results 1 to 11 of 11
It begins...
    Jun 2005
    It begins...
    Gonna build up an AR.
    I'm thinking 16 or 20" bull barrel, flat-top, free float, etc...
    Gonna try to swing some LaRue and LMT stuff if the budget will allow.
    Any suggestions?
    Member 636's Avatar
    vermont,orleans
    Lifer JohnnyV's Avatar
    Westborough, MA
    It begins...
    Only problem with the flat top upper is that you won't be able to shoot it in any DCM matches if you're looking to compete at all
    Member mostly.lurking's Avatar
    Central CT
    Look around at AR15.com
    I've been sponging all I can from that site. My bull build is:
    Stag Lower
    CMT flattop Upper
    ACE Skeleton Stock
    Rock River Arms 24" bull barrel
    Rock River Arms bolt & carrier
    Rock River Arms NM 2 stage trigger
    Yankee Hill Machine rifle length 4 rail free float
    A.R.M.S #35 QD Scope Mount
    Harris 6-9" bipod
    All I need to complete it is a scope.
    So far I have ordered from
    Adco Firearms
    Bravo Company USA
    Del-Ton, Inc
    Eagle Firearms
    Global Tactical Supply
    PK Firearms
    And I've had a good experience with all of them.
    Jun 2005
    It begins...
    Quote Originally Posted by mostly.lurking View Post
    That's good to hear.
    That's a fine looking setup.
    How long ago did you buy your RRA stuff? I had an RRA stripped lower on order until I found out the backorder was 4-6 MONTHS. I was lucky enough to find a Bushy in stock that some guy had ordered and abandoned, so I snatched it up.
    Anyway, I heard that they're really struggling to keep up with demand and they give preference to complete rifles (for obvious reasons), so getting parts requires a ridiculous wait.
    Central CT
    It begins...
    I got the RRA barrel Here and it was a year ago. It looks like Adco might have some of the bulls in stock.
    Jun 2005
    It begins...
    Some progress:
    Bushy stripped lower,
    DPMS lower parts (8000 grit polish on the hammer/trigger surfaces)
    DPMS flat-top upper
    16" bull barrel 1 in 9"
    picatinny gas block
    Free float tube
    Soon to get Troy Industries BUIS and hopefully an ACOG if my wallet can take it...
    Still trying to decide on a stock. It has to be fixed in th PRMA, so I'm somewhat limited. I'm thinking Magpul precision, but the rifle is already heavy enough with that bull barrel. I dunno.... more to come.
    Mar 2004
    woonsocket ri
    It begins...
    You will want a stock with weight in the buttstock to balance the front of the rifle. Otherwise it will want to tip forward and you will have to fight that as well as trying to hold it steady. Most of the people use a lead weight. You can shave it to get the balance you need. Bushmaster sell just the lead weight.
    Whats the pull on the trigger? You should have gone with a Geissele two stage trigger. Only $279 and may be one of the best triggers out there.
    May 2003
    Lakes Region, NH
    It begins...
    I mention this a lot but check out the Equipment Exchange on AR15.com. You can get a LOT of good buys there.
    Bras cause cancer.
    Mar 2004
    woonsocket ri
    It begins...
    [QUOTE=Nikon;343608]I mention this a lot but check out the Equipment Exchange on AR15.com.............QUOTE]
    Counting this time I think you are up to once.
    Jun 2005
    It begins...
    Quote Originally Posted by dhuze View Post
    good point...
    The Magpul is 28 ounces... so as long as it's not too heavy (highly unlikely) I'll be fine.
    The trigger is currently stock DPMS... an upgrade is coming somewhere down the line. I just wanted to get it built first and I still have to save some $$ for an optic. I agree that Geisele looks nice. I need a third job.
    I've been lurking over at the AR15.com equipment exchange... every retailer I call doesn't have the Magpul in stock, and I haven't seen any pop up there, but I'm in the market for other stuff, too. Lots of good deals... it's dangerous for the wallet over there.
    Can't wait to get it done. On deck is a .308 bolt-action.
  1. And it begins
    By R1 in forum Off-Topic
    Last Post: 12-31-09, 07:49 PM
  2. AND THE SEASON BEGINS!!!!!
    By MotoFreak in forum General Bike Related
    Last Post: 03-28-08, 09:11 PM
  3. The 'tardation begins...
    By Tricky Mike in forum General Bike Related
    Last Post: 11-08-05, 09:17 AM
  4. Hydration begins
    By Paul_E_D in forum Pit Area
    Last Post: 07-19-05, 02:24 PM
  5. So it begins...
    By oreo_n2 in forum Off-Topic
    Last Post: 02-01-05, 11:26 AM
