Results 1 to 18 of 18
Car stereo question
    Lifer obsolete's Avatar
    Norf Sho
    Car stereo question
    I've been digging online and I can't find any info on this, hopefully some one can help me out (I know there are a few audio guys out there. I have a 2006 Chevy 2500 with the non-bose non-onstar 6 speaker components in the front doors. Is there a cross over in there? If I put a regular speaker in there will I have to go in and dig it out? Or could I buy a component speaker set up and just plug and go?
    -Alex
    Southern, NH
    Re: Car stereo question
    Side note --
    Alex - do you know anyone in the Wilmington area that does installs?
    You might have to go to a shop and ask. Sometimes the factory component speakers can't be broken up, meaning you would have to buy a whole setup
    Banned G21forme's Avatar
    Lakes
    no idea about your stock stuff but would guess it has a crossover
    Will you be wiring them to an amp/new deck/stock deck? I'd just buy a set of components that'll have a crossover and run thicker wires. Have you called crutchfield? I have not done any audio work in forever but they might be able to help you out.
    Norf Sho
    Side note --
    No I do not. I would be putting my own stuff in.
    Well, they're toast so they're coming out anyway, I just need to know if I can hook up a after market component set up to the existing speaker wires or go back and find the crossover. Well, unless the crossover is in the deck.
    -Alex
    Central VT
    Talk with the folks at Crutchfield. They know pretty much everything about stock car stereo. 1-800-319-8943
    Jake
    2006 ZX-10R
    1999 Kawasaki ZRX1100
    Norf Sho
    I didn't know if they gave tech support if you weren't buying. Cool, I'll give them a chance.
    -Alex
    The components in the door are either going to be crossed over in the factory amp or via crossover cap at the mid in the door and then branched over to the tweeter.. if you need any help with the install we here at Boston Moto would be more than glad to help and can offer you pick up and delivery of the vehicle if needed. give me a call at 774-200-6395 for some more advice or to set up the install.. if you are going to be placing in an aftermarket set of component speakers it is sometimes best to just run new wires into the door or to the mid range wires in the kick panel then tap off to the aftermarket crossover wherever you place it.
    Derry NH
    The stock speakers in that tuck are branched off in the door. The woofer runs full range, and the tweeter has a capacitor for a high pass crossover.
    Very easy install. Just use one of the pairs of wires (I usually use the woofer wires) and secure the other plug to the harness to keep it neat in there. The stock setup in those trucks makes it all too easy to install a set of aftermarket separates. Tweeters maount up easily in the stock location, and plenty of room on the back of the door panel to mount the crossover. If you are gonna just run a set of coaxials, just wire it up to the woofer wires and unplug the tweeter.
    Norf Sho
    Eric, you're the man.
    I gotta hack these out and get something else in there stat. Sucks I don't have a garage anymore though, gonna be a cold one lol.
    Any recommendation on a coaxial or separates that won't be under powered by the stock system?
    -Alex
    Derry NH
    The stock stereo in there is actually pretty decent power wise. On-par with aftermarket units. You should be able to power most any coaxial just fine, borderline on the separates, but doable. I'm personally a fan of Polk, Alpine, and mid-high-grade Pioneer. Infinity's are good, but a little too tinny in the highs for me. Other good ones are Kenwood, MTX, JL Audio. The other good stuff needs an amp, like Boston, Focal, the good JBL, MBQuart etc.
    Central VT
    If you're concerned with under powering them compare the efficiency of the speakers. It will be measured in decibels(db) with (1) watt of input measured (1) meter away. The higher the db value the louder the speaker will be with a given amount of wattage. It is often referred to as "sensitivity".
    example: sensitivity: 86 dB
    Jake
    2006 ZX-10R
    Norf Sho
    Great info, thanks guys!
    -Alex
    TWINS! xrocket21's Avatar
    Central Maine
    You are wlcome to use my heated garage bro!
    Norf Sho
    Don't think the truck will fit lol.
    -Alex
    Central Maine
    thats true lol
    Norf Sho
    I really appreciate the offer but height and length I think wouldn't let it happen.
    -Alex
    Central Maine
    Now that I think about it, I have had our reg cab chevy in there, and it was tight with the workbench. Height would be okay, but we wouldnt be able to shut the door I dont think :o
  1. Stereo Speaker Help - for Music + TV
    By Point37 in forum Off-Topic
    Last Post: 05-01-17, 08:24 AM
  2. Stereo receiver for shop
    By Rada in forum Off-Topic
    Last Post: 07-07-14, 08:27 PM
  3. & FREE CAR STEREO STUFF
    By scubasteveRR in forum For Sale
    Last Post: 09-07-11, 07:47 AM
  4. Aiwa Car Stereo CDC-MP3
    By deeto in forum For Sale
    Last Post: 04-19-07, 10:53 AM
  5. Car Stereo Install
    By GMAN226 in forum Off-Topic
    Last Post: 03-21-06, 07:24 PM
