Results 1 to 6 of 6
Well questions....
    Nov 2004
    Boston, MA
    Well questions....
    We have a drilled well in the new place in NH...
    How does the electric pump work in a well? Is it continuously pressurizing the system? Only going on when the water is turned on? Is there some type of collection tank that refills?
    How long does the water run for (if at all) if the power is out?
    Thanks!
    EVERYTHING is a repost
    06 749R #0047
    08 R 1200 GSA
    13 Monster EVO 1100
    Re: Well questions....
    normally you have a pressure tank in the basement with a pressure switch in the tank that turns the pump on and off when necessary.
    when the power goes out, the pump can no longer turn on so as soon as you run out of pressure you loose water, could be low on pressure and need to turn on as soon as you open the faucet or you could get a few gallons if the tank was fully pressurized. depending on size of tank.
    in mine, as much as 7-8 gallons iirc
    if electricity/water is a serious concern, get a backup generator
    Northampton, MA
    If there is no pressure tank, get one. Biggest you can.
    Power goes out, you can continue to brush teeth, make dinner, wash hands etc with nO power until the pressure bleeds down. Also keeps your pump from short cycling.
    I put an oversized tank in my house when I built it, I think it's a 22 or 24 gallon tank. As mentioned already, you can usually wash up a couple times, flush the toilet a couple times and be fine. Even when the pressure is low, you can still go down to the tank and get water from it if you need..at least if it's like mine you can. So in theory, you should be able to get at least 3/4 of the total volume of water
    Any water source works to fill the back of a toilet to make it flush, brook, lake. with a gravity septic system, you can do that forever, with a pump system, yer in the same boat as well water, once the pump chamber fills up, its no takin shits either
    Banned Rambunctous's Avatar
    Waterville Valley, NH
    Kill the power at the fuse box and see what happens. Some wells have natural water pressure and actually need to be capped off and controlled.
    http://www.wisegeek.com/what-is-an-artesian-well.htm
  1. Duc questions
    By feralchimp in forum General Bike Related
    Last Post: 05-25-13, 01:59 PM
  2. HID questions
    By ZX11D in forum General Bike Related
    Last Post: 11-14-09, 01:24 PM
  3. RM 125 questions
    By 13 in forum Dirty Bastards
    Last Post: 09-18-06, 04:40 PM
  4. 20 Questions
    By hqp921 in forum Off-Topic
    Last Post: 08-15-06, 01:35 PM
  5. TDI questions..??
    By Ecooke21 in forum Off-Topic
    Last Post: 12-30-05, 04:45 PM
