Results 1 to 15 of 15
Sand blasters
    Lifer Falko's Avatar
    MoonTown
    Sand blasters
    Looking for a small media blaster, probably pressurized unit. What do you guys have that you'd recommend? This is only for touch up work on things around the house (boat trailer, lawn stuff, etc.)
    I know about filtering the media, and my air compressor isn't big enough, etc etc. Just what do you use that is reliable when all the planets are aligned properly that doesn't jam easily and doesn't need new nozzles every 10 minutes.
    thanks
    Lifer golden chicken's Avatar
    Attleboro, MA
    Re: Sand blasters
    A piece of hose and a blow gun makes a poor man's media blaster. You just split the hose and put one end in your media and the blow gun in the split.
    Raymond NH
    Re: Sand blasters
    I have been using a really cheap HF sand blaster for years and it works adequately, but will overwhelm my 60 gallon, 3 HP compressor pretty easily. I think I paid 10 bucks for it. I think I'd shop there for a pressurized unit too. An occasional-use/homeowner sand blaster is one of those tools that is too simple to require much engineering (and cost), IMO.
    MoonTown
    Re: Sand blasters
    Stoinks, do you have the siphon unit or the pressurized? I have a 2HP horizontal compressor and a secondary tank attached for more capacity installed for garage use. I plan to connect my oilless vertical, 40gal, into the mix as a secondary. I'll base load the 2 HP and let the oilless trim as needed. I don't have a lot of work to do with it but hate waiting for the compressor to charge.
    Re: Sand blasters
    For small items, I had great luck with a $25 hand held sand blaster from tractor supply. It looks like an older paint spray gun. My DeWalt 20 gallon compressor had no issues keeping up given the amount if media it held
    Raymond NH
    Re: Sand blasters
    Mine's a siphon unit, thus the inefficiency. A gravity feed on a pressure tank would be superior. If you already have multiple tanks, I would not bother with a pressure tank blaster, you only need the head. I like your plan. The next time I run mine, I'll connect my portable (an older 1 HP 20 gallon oiled type) in parallel.
    I may get a gravity feed blaster too, it would have less lag time and use less air. I have a friend's VP SX stern drive to blast and can use it as an excuse to upgrade.
    Raymond NH
    Re: Sand blasters
    HF 25% off anything coupon code, good until Dec. 13: 83591594
    MoonTown
    Re: Sand blasters
    After looking at them, I may just go with a gravity gun to see if it works. If I need something bigger, I'll go that route. I'm running out of space to store things.
    Raymond NH
    Re: Sand blasters
    That's funny, I had a gravity gun in my basket and then took at long look at that VP stern drive and bought a 20 lb pressurized feed unit instead (using the coupon code). I also bought three face shields. They are necessary for non-cabinet blasting work and they wear out fast.
    MoonTown
    Re: Sand blasters
    How did the 20lb unit work out? I'm still in the hunt. But I need to blast the wheels on the little car to refinish them this spring so it has become a bit of a need now. I do have access to our 10hp 300gal compressor at work now, so air shouldn't be as much a concern.
    South Coast MAsshole
    Point37s Garage Sale Thread
    MoonTown
    Re: Sand blasters
    linky no worky
    Re: Sand blasters
    linky no worky
    fixed...probably not what you're looking for though
    MoonTown
    Re: Sand blasters
    Thanks.
    I've been watching CL but I just want to be sure what I get is going to work for me.
  1. Skene Photon Blasters
    Last Post: 06-23-19, 05:46 PM
  2. For Sale - Other | sand pail
    By cdovego in forum For Sale
    Last Post: 10-17-15, 11:44 AM
  3. How should I sand this?
    By mell0 in forum General Bike Related
    Last Post: 05-11-12, 12:38 PM
  4. Sand all over..
    By toocrazy2yoo in forum General Bike Related
    Last Post: 09-05-10, 06:54 PM
  5. Nothing to see but sand... Still here.
    By Half Squid in forum Off-Topic
    Last Post: 03-25-09, 09:44 AM
