Page 2 of 2 FirstFirst 1 2
Results 26 to 35 of 35
Thanks for the help today CEO and a bunch of dummies
    Lifer obsolete's Avatar
    Norf Sho
    Re: Thanks for the help today CEO and a bunch of dummies
    What is the top of the bench in the finished pictures? It doesn't look like ply.
    -Alex
    Mar 2004
    woonsocket ri
    Reading is your friend.
    The top is just 3/4 plywood for now glued and screwed. I also plan on adding 2x12 framing lumber as a bench top for added strength. I'll screw those on from the underside through the 3/4 plywood. After that, I'll cap the ends with a 2x6 or something so you won't see any end cuts, and to cover the framing you can see in now.
    Norf Sho
    Quote Originally Posted by dhuze View Post
    He said he was planning on it, didn't say he did it. Thanks for the help though.
    -Alex
    Cleared AC plywood or something of the like
    bump...ya make any changes? just finished mine
    I havn't done anything to it and it looks like it did in the last pic..only a little more messy.haha
    I finished it exactly like I said i was going to. I used 2x12 framing lumber for the bench top, 2x8 framing lumber for the bench edges and backer board, then put 3 coats of clear poly over everything. So far it has proven great for clean up if something is spilled, or you get greese on it.
    Norf Sho
    So the bench top is only about a foot wide?
    -Alex
    Mar 2004
    woonsocket ri
    The framing hammer in the first photos is 16" and there is a 2' level as well, so I'm going to say it is about 2' wide using my awesome estimating skills.
    You're VERY close 23-15/16"
    Two 2x12's side by side and faced with a 2x8.
    11-1/4" + 11-1/4" + 1-7/16"= 23-15/16"
    Norf Sho
    I didn't even look at that pic. What did you fill the gap with?
    -Alex
    Mar 2004
    woonsocket ri
    So it is 2'. I added for that gap you left between the boards.
  1. Replies: 7
    Last Post: 05-27-14, 08:04 AM
  2. The best CrashTest Dummies cover EVER!!!
    By Uncle Snake in forum Off-Topic
    Last Post: 09-27-11, 07:04 PM
  3. ldap for dummies
    By daviid in forum Off-Topic
    Last Post: 05-05-09, 09:59 AM
  4. Car Audio for Dummies?
    By csmutty in forum Off-Topic
    Last Post: 03-02-09, 02:05 PM
  5. Dealerships Near Central or SE MA for Dummies
    By hqp921 in forum General Bike Related
    Last Post: 08-14-06, 01:52 PM
